757C backhoe subframe from 1720 to a TC33D
   / 757C backhoe subframe from 1720 to a TC33D
My 757C hasn't been used for a few years so it has some clutter around and on it. I did however take a few pictures (see attached) of the width of the frame where the pins attach near the loader supports for you. The internal width is 18.5" and the overall width is 21.75" This should help confirm the dimensions Spitter gave you. Let me know if you need anything else.
Thanks for this. I sent the request to the seller to make similar measurements to the 1720 subframe. If it's close, I'll probably buy it, and start looking around for the tractor-side brackets. For some reason, the one that fits the backend of the 1720 is $190, but the one for the TC33D is over $500. The two ears up by the loader mount should be easy...but the one in the back is much more complex.
Cart (A55853)
Cart (A55853)
5 - OIL WHEELED DRAIN PANS (A55745)
5 - OIL WHEELED...
1977 Gleaner A630 Corn Head (A57024)
1977 Gleaner A630...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
A45G DUMP BED (A55745)
John Deere 1025R (A53317)
John Deere 1025R...
