755 went down on me
/ 755 went down on me #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
after 3400 hours of use, she is going to cost me some money. It developed a fuel leak where the fuel lines come out of the pump and go to the injectors. I fixed the leak and she would only run on 2 cylinders. I took the line loose on the number 3 line and it was getting fuel but it did not change the way it was running. Then I loosened the number one cylinder line and it ran worse. I talked to my deere mechanic and he said it was either an injector or a bad piston. He seems confadent that it is an injector. I hope he is right. I am thinking maybe it needs a new home as it is starting to nickel and dime me to death but I hate to trade since we bought the 4700 this spring.
/ 755 went down on me #2
Three new injectors are cheap...my money is on the injector also.
/ 755 went down on me #3
Agreed...also....if you got a good diesel "pump shop" around, you could probably have your 3 injectors rebuilt for the price of one new one...
My deere mechanic called today and said they found a broken spring on top the injector I believe. He said that it could be just a broken spring but would not know until they got the new one.
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2000 Ford F-250 4x4 Service Truck (A66736)
2000 Ford F-250...
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2015 Kubota...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
