Oil & Fuel 755 Stalls frequently
   / 755 Stalls frequently #1
Jim Wieler
Medway, MA
John Deere 755
My 1986 755 has been a gem, but recently it is stalling frequently. When this happens the fuel filter glass bulb is empty. If I open the bleed valve the bulb fills and tractor starts happily. Any ideas? I have had a little sediment at the bottom of the bulb.
   / 755 Stalls frequently #2
:welcome:
What have you done to clear the line up-stream from the bulb?
Some use air pressure to blow back in the line to see if there are obstructions that have built up.
   / 755 Stalls frequently #3
Does yours have the small electric fuel pump ? It won't run much off idle if that go's , I also had to clean the tank on mine it was packed with that algae that grows in diesel
Good ideas...both.
I did check the line and no fuel flowed. I thought that the tank outlet may have a one way valve or something. If that isn't the case I'm pretty gummed up! How do I get rid of the gunk? Thanks
   / 755 Stalls frequently #5
Turn the key to the on position , Can you hear the electric pump running ? Disconnect the line between the mechanical pump and the electric , Get something to catch the fuel , Turn the key to the on position see if any fuel runs at the outlet side of the pump. Should be a steady flow ! To degunk your tank , First, Drain the tank, remove the hood, grill and side panels. Then pull the sending unit out of the tank , Be careful not to wreck the gasket under it or any wiring. Then I removed the lines and tank. I fashioned a giant Q - Tip ( steel rod, rags, and duct tape ) to swab out any gunk in the tank and rinse with clean fuel. Then clean the brass screen on the sending unit mine was packed. Now reinstall.
   / 755 Stalls frequently #7
The cap is also vented-make sure it works. After it stalls or while it's stalling open the cap and see if you here air rushing in, meaning the tank is under a vacuum so the fuel won't flow.
2022 TORO MBTX-2500S STAND ON MUD BUGGY (A52709)
2022 TORO...
CFG Industry MH12RX Mini Excavator (A57149)
CFG Industry...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
PIECE OF 4'X76" 3/16" THICK SHEET METAL (A58375)
PIECE OF 4'X76"...
2023 Texas Pride Trailers Trailer, VIN # 7HCM2UGT9PB039378 (A57453)
2023 Texas Pride...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
