755 power beyond kit, with pictures
   / 755 power beyond kit, with pictures #1
Kevin M
goshen NY
48" bobcat walk behind , 60" Dixie Chopper Classic , 755 John Deere 4x4 70 ldr belly mower etc etc , 7610 Ford 4x4 7412 ldr and 10 ft rhino hogg
Tractor with fenders, seat, seat brackets removed .
Rachet handle shows the factory plug that has to come out.
Here are more pictures of the outer plug you need to remove, so you can install the new smaller diverter plug. I colored it orange to better highlight the spot for pics.
The first picture shows the plug i removed on right, the one on the left is the new plug to be installed , also shown in the second picture. The third shows how far into the hole you have to put this before you actually catch the smaller threads. Then reinstall the factory outer plug. PS install thread sealer on factory plug.
The shiny glare in the third pic is a penny to show depth , the first part of the power beyond is done!
The next pictures show the two factory plugs that need to be removed, ( behind the loader valve) Again i colored them for the picture and the picture was taken from the rear of the tractor. The second picture shows the new O-ring boss 90 degree fittings to be installed where you remove the plugs.
This picture shows the new fittings being installed, one of the factory loader valve fittings needs to be disconnected to aid in installation.
Now attach the steel tubes, that run the fluid to the back of tractor and the bracket and rubber hose your done.
These are pics of the valve i added to run my dump trailer and snow plow angle.
Thanks again to KENNY D ! Without your help this would not be possible.
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2015 Nissan Rogue SUV (A56859)
2015 Nissan Rogue...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
