753
   / 753 #1
753
aragon ga
753 bobcat
I have a 753 bobcat front loader and I'm having trouble with my hydrolics when I raise my boom up. It won't come back down, when I tilt my Buck it down it won't come back up
   / 753 #3
Does that bobcat has some sort of regeneration valve ? It puts oil in the cylinder but doesnt let it back out. You can extend both cylinders but not get them in anymore, pushing them out requires more oil than pulling them in because pulling means the surface of the piston rod misses. You have a return flow problem of some sort, probably in an additional valve like a regeneration valve.
   / 753 #4
One of the auxiliary solenoid stems is stuck "on".
   / 753
Thanks I pulled those aux selonoids out and checked that was my problem its now working again thanks .
2014 Landoll VT-Plus (A52349)
2014 Landoll...
2018 POLARIS RANGER 570 EFI UTV (A51247)
2018 POLARIS...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
80in HD Tooth Bucket with Side Cutters (A52748)
80in HD Tooth...
KUBOTA M7-132 (A53084)
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
