7520 Starting problem - Help!
   / 7520 Starting problem - Help! #11
brisimon said:
Regarding the shuttle lever, correct me if I'm wrong, but I don't thing I've ever had to worry about that lever being in neutral to start the tractor - just the speed selector shiftstick needs to be in neutral, right?
Yes, the shuttle shift lever has to be in neutral also. I know on the new 7520's on out lot you have to have all levers in the neutral position to start.
   / 7520 Starting problem - Help! #12
brisimon said:
Just an update for everyone - I have been able to use the tractor by jumping
the starter, after having no luck trying the jumper method on the PTO switch, which I guess means that switch is not the problem.
I've been hurrying to get a project done, but hopefully tomorrow I can take a break to try to jumper the safety switch on the transmission, to see if that might be the problem.
Regarding the shuttle lever, correct me if I'm wrong, but I don't thing I've ever had to worry about that lever being in neutral to start the tractor - just the speed selector shiftstick needs to be in neutral, right? And under the speed selector stick is the wire I think I need to jumper to test that switch. If I'm wrong on that, please let me know.
But to BigTy's point, the first day I had problems getting started, I made sure everything was in neutral.
Thanks again, everyone!
Brisimon,
My 6520, just like your 7520, had a wire pulled off of the neutral switch on the bottom of the speed shift lever. There are two wires running to the switch. If you don't have two wires..........................one of them was ripped off while you were working. Mine was ripped off while I was clearing brush.
hugs, Brandi
   / 7520 Starting problem - Help! #13
not on my '06
   / 7520 Starting problem - Help! #14
I stand corrected, guess I was thinking about the 00 series
bindian said:
Brisimon,
hugs, Brandi
I still have both wires, but only one terminal to plug into. I've been having too much fun deer hunting, but just yesterday, I finally took the time to jumper the wires together. Just like that, the key will actually start the tractor now!
Thanks to everyone for the great input! Case closed (once I get the switch replaced).
Just to back up Larry's point, my 7520 is an '05 and only the speed shift lever needs to be in neutral to start the tractor.
Thanks,
Brian
2002 GREAT DANE 102" X 53' T/A VAN TRAILER (A51243)
2002 GREAT DANE...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
New 4-17.5 Forerunner Skidloader Tires (A50774)
New 4-17.5...
2008 INGERSOLL RAND DD-16 SMOOTH DBL DRUM ROLLER (A51242)
2008 INGERSOLL...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
Land Honor Skid Steer Pallet Forks (A50515)
Land Honor Skid...
