7510 Question
/ 7510 Question #1
Koz
Pittsburgh, PA
Because I preferred the ergonomics of the JD 2210 and 4110 to the BX, up to today I was leaning toward purchasing one of the two JD's. For some reason, the thought of looking into Kubota's larger tractors did not cross my mind. Fortunately, I spent some time at my local Kubota dealer today and am now considering the 7510 too.
I have 3.5 acres, half grass and half field. The field becomes very thick and becomes difficult work for my JD 445 (23HP gas with 60" deck). I want to upgrade to a diesel engine and have the ability to purchase a loader and other cat 1 implements. Maneuverability is important as I have many trees.
The 7510 is a much more comfortable tractor than the BX (to me). I am 6'-2", so maybe that is why. The seat on the BX almost seemed to lean toward the steering wheel. I do not notice this on the JD's or the 7510.
Will the 7510 be as maneuverable as the BX? I drove it around the lot and it appears the uncut circle with a 60" deck is approx 48". More importantly, will it cut as well as the BX? My neighbor has a BX with a 54" deck and his tractor does a great job. The dealer says that there should not be a difference.
I got a price of $11,800 for the 7510 with 60" deck and folding ROPs. Is this typical? Price wise, the 7510 seems to be between the 2210 (at $10,800 with deck) and 4110 (at almost $13,000 with deck) but it seems to be more comparable to the 4110 in its abilities.
Anything else that you guys have run across when comparing the 7510 with the JD 2210 and 4110?
/ 7510 Question #2
I have no experience with the BX but I do own a B-7500 and feel you will be very pleased. I use mine mainly to finish mow 3 acres and brush hog another 3. It will certainly be a step up form your 455. I do not have a mid mount mower, but many on the board tend to say the BX is a superior mower due to the fact the deck is suspended where as the 7510's deck rides on caster wheels. The price seems about right to me I paid $9700 on mine with folding ROBs and no mower 3 years ago I suspect the MMM will run you around 2 grand. The 7510 will compare most closely with the JD 4110, both machines will do what you ask as will the BX or 2210, I would chose the one that you feel is the most comfortable and with the dealer you like the best. Have fun shopping is half the fun. /forums/images/graemlins/wink.gif
/ 7510 Question #3
I had looked at the 7510 but decided to opt for the 7800 for ground clearance and more power and higher dump height. It was a tough decision as I liked the nimbleness of the 7510 Even on my 7800, it is a little cramped for my brother who is 6'4". I've always been told that if you are taller that the New Holland seat is more accomodating because it slides at an angle (back and up). If the 7510 is comfortable I don't think you would regret the purchase.
/ 7510 Question
I guess i'm confused about the decks. I always assumed that a deck that rode on casters would be superior to a suspended deck. Isn't that why so many people like Simplicity decks?
A concern did come to mind, though. As a significant portion of my mowing will be a rough field with lots of bumps, maybe a floating deck will take less abuse than a deck that rides on the ground.
/ 7510 Question #5
You may want to send a personal e-mail to a member named TresCrows he has both a BX and a B-2410, he says the suspended deck gives a better cut. Another option if your new property is really rough field you may want to hold off on the MMM and buy a economy brush hog in the $400 range and once you get it tame and work the surface smoother then get a MMM or a RFM. Good Luck!!! /forums/images/graemlins/smile.gif
/ 7510 Question #6
I would first ask why if you were leaning to the JD 2210 why not look at their larger units as well? BUT, being a Kubota booster /forums/images/graemlins/smirk.gif I think--of course--you should get the Kubota /forums/images/graemlins/shocked.gif. I like both my 2410 and my BX. The BX 60 inch suspended mower is a much better mowing utensil than the 2410 and its 60 inch deck on castors. The BX is more manuverable BUT again, now that I have my 2410 and have spent the time to set my deck up and also get used to the tractor I do like it very much. It does not cut as well as the BX, but still, now I am happy with it and I am reasonably particular. The castors tend to rut soft ground and also tend to lay over overly tall grass causing striping. The suspended BX deck is also better for cutting rough ground because it rides on the tractor tires and the castor type on the 2410 rides on little castors. That said, no MMM is made for really rough ground or bush hogging. They will be quickly destroyed and they are very expensive. My recomendation is for you to get the 7510, a 60 inch MMM and a 48 inch cheapo brush cutter like a King Kutter brand for you rough field. I sometimes cut my not terribly rough field with my MMM on either the BX or the 2410 with it locked full up.
I someties wish I had turf tires on my 2410 instead of R4s as well, and yes, the BX is easier on the lawn even with the mini Ag tires and more manuverable and is a fine little tractor in it's on right. The key word is little. Stepping up to a 7500/2410 size machine is not a huge move up in power but still, that size has more loader capability and works better with a boxblade.
As I am now going into my sixth summer here and I find myself looking for tractor work /forums/images/graemlins/confused.gif. Well, yes, my drive did wash out in a flood /forums/images/graemlins/cool.gif in the fall and Kubota to the rescue /forums/images/graemlins/wink.gif but other than that I could really probably get along well with a ZTR /forums/images/graemlins/tongue.gif /forums/images/graemlins/frown.gif. My BX is now in La. with my parents for now but for a while I had two tractors here and with two Kubotas going I was Hades on wheels.
Will I sell my Kubotas--NO--noway /forums/images/graemlins/grin.gif. I may buy some more land or maybe hire some kids to make a mess of my property so I can fix it /forums/images/graemlins/smirk.gif. J
/ 7510 Question #7
Only thing more I can add is that I recently priced a JD 4110 hydro here in MO with folding rops, r-4, 410 FEL, hood guard, 60"MMM at a price of $15,700. The decision seems (for ME) to be the hard part. I'm looking to make a purchase also. Seems that I have trouble separating what I really need and will use the tractor for with what I really want. Some people always want a little more than they need because they have plans or dreams of doing things they may or may not ever do. Seems like when you get into the $16,000 level there are lots of good tractors and you can't really go wrong with any of them, so the dealer really becomes important. And hey, only another $1,000 to the $16K and you can muddy things up! In the end, I think the smart money goes to what your real needs are going to be, but I keep wanting that little extra.
/ 7510 Question #8
A floating deck follows the ground with the tractor and allows smoother cut. A deck rolling on casters rolls on the ground and there's no pivot point so humps, etc, the cut is good but not as good as with floating decks. If you have level ground no humps, bumps etc the MMM is wonderful.
If you really want a better cut get 20" push mower... Or a gang reel.
/ 7510 Question
A thought....for the field cutting to a much higher elevation would certainly not be a problem. I have to do this now with my 445 to keep it from bogging. Couldn't I just raise the deck to the highest position when cutting the field and drop to 3" when cutting the lawn?
Given the difficulty changing deck height, if I go with the 7510 I do not see myself adjusting finish cutting height as frequently as I do with my current 445.
Its too bad that Kubota did not include the suspended BX style deck with the 7510. If they had, I think the 7510 would be an easy choice. Given my mowing quality concerns, I am likely to go with a JD 4110 if one of the local dealers comes up with a proposal that is competitive with the 7510.
/ 7510 Question #10
Koz
There is a suspended deck available for the B7510. The whole goods number for this deck is an RCK54-75B, it is a 54" mowing width deck. Hope this helps.
Lewis
/ 7510 Question #11
Since you had the JD 455 tractor styled lawnmower, you like most past owners of such equipment--tractor styled ride on mowers of any sort----is that you think in terms of the MMM only, I did the same thing. Yes, the 7510 can have the deck pinned up and I do cut like that, and the BX can lock the deck up and I have used it that way as well but using a MMM for field cutting is asking for it. Those things cost about 3,000 dollars and a cheap brush cutter about 500 --so which do you want to tear up. Some people will go to any expense to save a dollar. /forums/images/graemlins/crazy.gif
As to the JD4110, does't it have a plastic floor and hood? The deck on castors on the 7510 is not that bad but if the JD actually has a suspended 60inch deck that may offset things a bit. Good luck. J
/ 7510 Question #12
I can't see how you will get by without the 7800, BUT I'll let you off the hook. I do however command you to get the 7610!! /forums/images/graemlins/smirk.gif There! Now you can tell your wife that you had no choice.
Don't forget to ask for the straps, as those rusty chains are heck on the frame!!! /forums/images/graemlins/shocked.gif
Nice meeting you! Your the first TBN'er that I've ever met (off the board).
/ 7510 Question #13
BTW - Fill out your profile for cryin out loud! /forums/images/graemlins/tongue.gif
/ 7510 Question
Ok, Ok!! My profile is filled out!
Probably like you, i'm a bit concerned after treading the "Thinking about Selling the B7500" thread.
As we discussed, my observation of the 60" MMM's cutting ability when using the demo 7500 was that it was no worse than my current JD 445's.
The comment about wearing the lawn also has me a bit concerned, but i'm hoping that maybe it is partially due to running the tractor too fast. I did note during my demo that the 7500 was more likely to "push" the front tires straight instead of turning the tractor at high speeds.
Oh well....time will tell. My new 7610 should be delivered sometime this week. I already have a call into Kevin to make sure he does not use rusty chains on my new tractor!
/ 7510 Question #15
Try to do the close in cutting s-l-o-w and stay drive in straight lines as much as possible. I've found out the quick turns and the back up and turns and the yard are not the best way to cut the grass. Don't mow in 4 wheel drive, it'll ruin your yard.
Where I live, I have a yard and not a lawn.
The ZTRs when turned in their tracks do as much damage as the tractors do. It's the spinning the grass in a circle. The Dixon ZTR dealer warned me, and said most folks have to learn how to keep from ripping up the grass under the tires.
/ 7510 Question #16
I can tell you that technique has alot to do with it. I was turfing the lawn on many occasions when I first got mine. You need to accelerate out slowly, don't just hammer the pedddal. You need to try to choose good times to mow, I usually wait until it is a little bit dry. I'm sure you'll be fine!
/ 7510 Question #17
"I usually wait until it is a little bit dry. I'm sure you'll be fine!"
Yes, I do the same thing. Sometimes the tractor styled lawnmower guys have already cut the grass a day or two before me after a rain before I dare go out on it with the 2410. To do so would quickly destroy my yard. Down south at my parents place I notice that the St. Augustine floats the BX a little better than the fescue did. In either case, cutting a yard sooner than two full days after a good rain is pushing it. J
/ 7510 Question #18
One other thing. If mowing a hillside or slope sideways, when you turn around, do it to the downhill side. This lowers the amount of force the rear wheels have to deliver to the ground to get the machine turned around.
If you really think about it, it is common sense. I just took a while to figure some of it out. If you turf the grass, think about why it happened. Done right, I could surely mow my grass with a 7800 with little difference in overall look. I'd probably use huge turfs (properlt inflated). I'd airate twice a year instead of just in the fall. And so on...
BTW - I mow at 4" to 3.5" all summer long. I never go any lower. This has helped my lawn situation in several ways.
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
2001 UNKOWN  GOOSENECK PUMP TRAILIER (A65643)
2001 UNKOWN...
Goosen Bale Chopper Hay Blower (A65579)
Goosen Bale...
2008 CATERPILLAR 304C (A65643)
2008 CATERPILLAR...
2015 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2015 International...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
