7510 hydraulic system problem
/ 7510 hydraulic system problem #1
garygs415
I bought a Kubota 7510 for my first tractor a month or two ago and love it...well, all except the hydraulic system failed to work today. I had the trailer and front loader loaded with firewood, cranked it up to drive it back, and when I tried to lift the loader off the ground, nothing happened. No creaks, groans or anything! I tried to lift the three point hitch and it, too, wouldn't work. I didn't think to try the steering system. So now it's stuck way back in the middle of the woods and can't be moved. Does anyone have any suggestions? It's probably a new user mistake, if my past track record suggests anything.
Gary
/ 7510 hydraulic system problem #2
First thing to do is check the hydro fluid level. You may have simply overloaded, try unloading some weight and see if it works.
/ 7510 hydraulic system problem #3
Check hydraulic fluid level and if it good then you may need to look at the hydraulic pump.
/ 7510 hydraulic system problem #5
A hydraulic quick connector has come apart. It could be one that has come partly undone, but sounds like it is completely unseated.
