7510 7610 or what?
   / 7510 7610 or what? #21
I'm doing similar land clearing work with my tractor which is a Kioti CK20 but in the same general size class as the 7510/7610. From my experience over the past year or so in clearing out about 2-3 acres of scrub trees, briar, vines and a few dozen bigger trees, I'd say that the backhoe is very valuable. I find a combination of bush hog, grapple and BH to be ideal.
The FEL on a B series machine is not as powerful as the FEL on my Kioti and while I can push over a fair number of trees less than 3-4 inches in diameter, anything much bigger requires cutting and then digging out the stumps.
My tractor is also heavier so I'd estimate that the 7510/7610 would have a more difficult time pushing trees over which is an important step in digging them out with either toothbar or grapple. My FEL has about the same lift capacity as the LA402 so I'd have a bit of an advantage there too. While I think my tractor has done amazingly well I would not opt for anything smaller. I would therefore agree that the B7800 would be worth the extra money. However, if it came down to B7510 and a BH vs B7800 without a BH, I'd say the BH is worth more than the extra weight and FEL capacity.
If you are doing a lot of land clearing do yourself a favor and get a grapple. Although a toothbar adds something to the ability of an FEL bucket to deal with brush, a grapple is the tool you want. A bucket grapple would suffice but a full grapple is much more versatile.
Those are some great pics IT... I like the grapple idea. How much for one of those guys?
I would like to keep this purchase under 20k and I may be able to do that with the 7610 with a loader and bh. However, if I choose the 7800 or the L2800 like the dealer wanted me to get into than I will have to settle for just a loader with a toothbar and that's about it. Unless I can find something used with both implements at a great price.
Bottom line fellas is; happy wife...happy life!!
   / 7510 7610 or what? #23
Northshore44 said:
\I like the grapple idea. How much for one of those guys?
About $695 but you need to ship it from Ohio and also need a QA adapter and either a diverter valve or a set of rear hydraulic remotes. Total budget probably $1600-1800.
I got my CK20 with 28hrs on the clock, FEL, loaded tires, new BH all for $15K. I'd think you could do the 7610/LA352/BH for under 20K and perhaps have enough left over for the grapple. If the budget it tight, just go the bucket grapple route which will cost about $1000 including diverter valve.
Believe it. There is now scientific data to support that. If mamma ain't happy ain't nobody happy. :eek:
That's a fact Jack!!!
IT... sounds like you got a great deal!
What happens when you don't need that grapple? Does it get in the way? Can you take it off easily?
   / 7510 7610 or what? #25
The grapple has a universal quick attach mount so it comes off in about 20 seconds. Takes longer to disconnect the quick connectors on the hydraulic lines than to remove the grapple.
From those pictures you sent... that's exactly what I will be doing and looks like it works pretty slick.
   / 7510 7610 or what? #27
I agree with IslandTractor. The grapple is the stuff. With that on the front and a BH on the back you can really clear some brush. When I'm working in tight places or really don't need the BH I use the box blade on the back.
Look at my picture at the left and you'll see one of my little projects.:)
   / 7510 7610 or what? #28
I don't have a box blade so when I am not using he hoe I keep the bush hog on the back. Awesome combo versus lighter brush or for clearing a path to the trees that need to be dropped. Grapple the brush then run over whatever remains. Quick work.
   / 7510 7610 or what? #29
Northshore44 said:
What do you think about a bh? Is that neccessary for what I will be doing? Dealer claimed it would add another 6k to the price.
I grubbed 6/10 of an acre. Wouldn't wanted to even attempt it without the BH .
   / 7510 7610 or what? #30
Northshore44 said:
I am thinking the same thing... I am not sure I will be able to drive into the lake and rip the brush out w/ just a loader without getting stuck.
*I would feel better on land and then reach out with a hoe and pulling it all back.
1*What you have to watch doing this is that the BH don't drag you and the tractor into the lake.
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A54756)
(INOP) 2016...
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55314)
2023 New Holland...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
2007 Hyundai Sonata GLS Sedan (A55853)
2007 Hyundai...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
