7500 rear end noise??
/ 7500 rear end noise?? #1
Darins
Stanwood Wa.
B7500
I was wondering if anyone else has heard this or is there something wrong with mine? I have almost 100 hr on my 7500 and lately when I go slow I can hear barring noise coming from the rear end? It sound like little barring turning in there. Are they suppose to do this or is there something wrong? When someone else is on it and I stand next to it I can really hear them. Should I take it in or do you think that normal? Thank you Darin..
/ 7500 rear end noise?? #4
Darin,
If the noise is recent and you feel uncomfortable with it, it may be wise to take it into the shop for warrenty work.
Terry
/ 7500 rear end noise?? #5
darin: any strange noise that u are hearing now , and not in the first 100 hrs. is cause for a check. i would let the dealer checkit out.are u sure it is from the trans.?
/ 7500 rear end noise?? #6
When I had a 7500 I also had a noise and what I found was the bolts that hold the rear wheels on the axle were lose. There is some type of collar there to adjust how wide the wheels are spread and they needed to be tightened.
/ 7500 rear end noise?? #7
As others have suggested, the real test is whether the noise is new and/or increasing, or if it's been there all along. HSTs normally make a buzzing sound and a wine when they are under load. Saying that is easy. Drawing the line between normal and abnormal sounds is a lot harder on paper (virtual paper in this case).
The suggestion about checking wheel bolt and hub pinch bolt tightness is an excellent first step to rule out other simple causes.
/ 7500 rear end noise?? #8
<font color=blue>Drawing the line between normal and abnormal sounds</font color=blue>
Ain't it the truth?/w3tcompact/icons/wink.gif The only time my tractor has been back to the dealer was because of an intermittent rattle I couldn't find. I finally thought I'd found it; in the front "propellor shaft"; dealer removed it and put it back without finding anything wrong, but stopped the rattle (or at least I thought so). However, this past week I occasionally noticed it again, along with some other different sounds. Hmmm . . ., I think it might have something to do with these new hearing aids./w3tcompact/icons/laugh.gif
/ 7500 rear end noise?? #9
My BX2200 does that, but then I realize I've been mowing with the brake on (again).... /w3tcompact/icons/wink.gif. Seriously though, even though it's a different model, I was suprised by the amount of noise which comes from the rear end.
- Patrick W.
/ 7500 rear end noise?? #10
<font color=blue>Hmmm . . ., I think it might have something to do with these new hearing aids.</font color=blue>
Just turn 'em down a little and those troublesome sounds will go away. /w3tcompact/icons/wink.gif
/ 7500 rear end noise?? #11
That's why I always spent the extra buck on a great car stereo. It's amazing how nice a car is when you can't hear anything!/w3tcompact/icons/laugh.gif
Jeff
/ 7500 rear end noise?? #12
<font color=blue>turn 'em down a little and those troublesome sounds will go away</font color=blue>
They darned sure do; along with all the other sounds I want to hear./w3tcompact/icons/laugh.gif
/ 7500 rear end noise?? #13
Or let your wife or children drive the thing around for a while! /w3tcompact/icons/blush.gif
Me - "Dear, didn't you hear that sound?"
Wife - "What sound???"
Me - "Nevermind" As I pick up the phone to call the dealer for service. /w3tcompact/icons/shocked.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/smile.gif
Terry
/ 7500 rear end noise?? #14
A guy I knew in high school had a Datsun Z car. It had an awful whine coming from the rear end. He knew it was gonna be time for a new rear end soon. In the mean time he put a new exhaust system on it. Brrrrraaaaapppppp Braaaaaapp from the exhaust was all that you could hear now. About four years later he got tired of all the extra noise and put the old muffler back on. And that darn bearing noise from the rear end had been there all along! It had just been covered up by the loud exhaust this whole time. The funniest part was that the whine from the rear end still drove him crazy after all that... He just knew the rear end was gonna blow up one day!
/ 7500 rear end noise?? #15
He should have just pulled the fill plug and jammed a few ripe banana's in there, that would have shut the carrier bearings right up!!! /w3tcompact/icons/wink.gif
- Patrick W.
/ 7500 rear end noise?? #16
<font color=blue>Brrrrraaaaapppppp Braaaaaapp </font color=blue>
We know what this sound is!! Get some Beano!! /w3tcompact/icons/blush.gif/w3tcompact/icons/laugh.gif
Terry
2023 KOMATSU D51EX-24 CRAWLER DOZER (A65053)
2023 KOMATSU...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
Kubota L2501D 4x4 Utility Tractor with Land Pride 72in Brush Cutter (A64553)
Kubota L2501D 4x4...
2017 Ford Fusion (A64557)
2017 Ford Fusion...
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
2020 Inifiniti Q 50 Sedan (A64557)
2020 Inifiniti Q...
