74 f600 high ranger bucket truck
   / 74 f600 high ranger bucket truck #2
i've seen a couple of those what you got going on?
sorry for delay, wrong hydraulic fluid was put in so base controls work fine, bucket controls are slow or dont respond, the port holes in the valves from the small pistol grip tubing are small the 46 is a 20w fluid so it flows too slow through the holes, mechanics tell me they use atf msds specs are the same as the mil grade 5606 which cost a trillion dollars, so i would have to drain and filter change and fill with atf or a hy tran fluid of 10w, sound correct
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A55218)
2019 BOBCAT T630...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2012 NORAM POWER...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
