74 f600 high ranger bucket truck
   / 74 f600 high ranger bucket truck #2
i've seen a couple of those what you got going on?
sorry for delay, wrong hydraulic fluid was put in so base controls work fine, bucket controls are slow or dont respond, the port holes in the valves from the small pistol grip tubing are small the 46 is a 20w fluid so it flows too slow through the holes, mechanics tell me they use atf msds specs are the same as the mil grade 5606 which cost a trillion dollars, so i would have to drain and filter change and fill with atf or a hy tran fluid of 10w, sound correct
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
17101 (A53421)
17101 (A53421)
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A52705)
2016 CATERPILLAR...
