737 ZTrack Kawasaki 23HP
   / 737 ZTrack Kawasaki 23HP #1
gregggg
maumee oh
Blew the engine (FH680D-AS04) and Deere wants $3000 for the engine alone with no install. Seems as if Deere has this engine on a restricted list which you can't find it other than through your Deere dealer. I found a similar engine (FH680D-S08) which appears to be the same only doesn't have the shaft and pulley coming out the flywheel side oif the engine. This engine is around $1,800. Wondering if I can purchase it and bolt my shaft / pulley on it and be okay? The pully is used to drive the belt for the hydraulics on each wheel. Thoughts / Comments? Thanks,
   / 737 ZTrack Kawasaki 23HP #2
I have the same problem described above. I have a John Deere 737 with a Kawasaki FH680D Engine that is blown. Has anyone replaced the engine with a new Kawasaki FH680D-S08 or FH680D-S01 engine? If so, can you tell me exactly what modifications you had to make?
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
2023 KOMATSU PC55MR-5 EXCAVATOR (A52705)
2023 KOMATSU...
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
CAT 973 (A47384)
CAT 973 (A47384)
2017 Hino 268 26FT Box Truck (A55788)
2017 Hino 268 26FT...
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
