7340 zetor
/ 7340 zetor #1
marshallmatt
great hp tractor, however the brakes and clutch cylinder could use better seals, have replaced three times with just 2100 hours. The power steering is the best, better than any auto, starts quick, its not hard on fuel.
/ 7340 zetor #3
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Zetor, Century, Branson Forum. You'll get a better response there. ;)
/ 7340 zetor #4
Some of the older slave and master cylinders on Zetors were not very well made, but make sure your dealer is buying the latest versions from Zetor in Harrisburg, Pa. There are many aftermarket items out there that are not the best. If you need more help, contact Peter Laznicka, the Service Mgr. at Harrisburg. He is excellent and will give you good advice. Sorry I don't have a number, but you can get it on the web, under Zetor North America.
Best Regards,
Iron Peddler
/ 7340 zetor #5
I assume you try to repack those cylinders ? Its a waste of time, the seals arent the problem: the problem is that on the early PAL brand cylinders, the liner coating loosened and the roughness keeps eating the seals.
You need to use new cylinders, of the Fragokov brand which are also used on newly built tractors off the factory.
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
Sakai SW354 (A60462)
John Deere 3025E (A53317)
John Deere 3025E...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
1988 FRUEHAUF TRAILER OPERATION FUEL TRAILER (A60736)
1988 FRUEHAUF...
