7340 zetor
   / 7340 zetor #1
marshallmatt
great hp tractor, however the brakes and clutch cylinder could use better seals, have replaced three times with just 2100 hours. The power steering is the best, better than any auto, starts quick, its not hard on fuel.
   / 7340 zetor #3
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Zetor, Century, Branson Forum. You'll get a better response there. ;)
   / 7340 zetor #4
Some of the older slave and master cylinders on Zetors were not very well made, but make sure your dealer is buying the latest versions from Zetor in Harrisburg, Pa. There are many aftermarket items out there that are not the best. If you need more help, contact Peter Laznicka, the Service Mgr. at Harrisburg. He is excellent and will give you good advice. Sorry I don't have a number, but you can get it on the web, under Zetor North America.
Best Regards,
Iron Peddler
   / 7340 zetor #5
I assume you try to repack those cylinders ? Its a waste of time, the seals arent the problem: the problem is that on the early PAL brand cylinders, the liner coating loosened and the roughness keeps eating the seals.
You need to use new cylinders, of the Fragokov brand which are also used on newly built tractors off the factory.
2012 Dodge Journey SE SUV (A48082)
2012 Dodge Journey...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A51039)
2007 Freightliner...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2017 Ford Fusion SE Sedan (A48082)
2017 Ford Fusion...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
