7320 Fel joystick is sticking
   / 7320 Fel joystick is sticking #1
kmwahoo
Wahoo, NE
Bobcat
I have 10 hours on my 7320 athe joystick starts to stick when it gets warm. Its strange because it doesn't stick everytime. I know pushing down it will stick in float. Any ideas?
   / 7320 Fel joystick is sticking #2
Does it only stick pushing down? There is a detent that if you push all the way will hold it in float. Not sure if that is what you are seeing or not. That would be normal.
It does it going up and down. It sticks real bad. I know what float is. I'm an experienced operator.
   / 7320 Fel joystick is sticking #4
No disrespect intended.
Not familiar with 7320. Does it use cables to control spool valve or is the joystick mounted on the valve? If cables, I would start there to make sure they are not binding. Then I would take valve apart to clean and inspect.
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
2020 DRAGON ESP...
2017 Ford (A55973)
2017 Ford (A55973)
