7308 Hoses Will Not Connect
   / 7308 Hoses Will Not Connect #1
Boomer33
Sullivan Co., NY State
NH Boomer TC33D & 1951 Ford 8N
I need help quickly! I have someone coming tomorrow to replace footings on my porch and I need my loader to lift and sopport the deck to shor it up. I tried to mount the loader today with no luck. I can't get the couplers to engage no matter what I do. I tried to relieve pressure by draining oil from the sump. I tried hitting the pins on the male (loader side) with a hammer and striking the female (tractor side) with a drift pin all to no avail! I removed the loader in March when the average temp. was 40 degrees. Today it is 84 degrees where the loader sits. Am I beat? Should I cancell the appointment for tomorrow? Does anyone have any ideas?
Dissappointed and frustrated am I and my wife is loosing her appreciation for tractors as the ultimate power tool! Please HELP!
Arthur
   / 7308 Hoses Will Not Connect #2
Take a wrench and just loosen the hose ends at the cylinders, or where the Quick disconnect threads onto the hose end. You might want to wrap a rag around the fitting so it doesn't spray all over the place when you do it.
   / 7308 Hoses Will Not Connect #3
Arthur, with the tractor engine off, you can move the joystick around in all directions and that relieves all the pressure on the tractor side; nothing more need be done. On the hoses (loader side), I've never had any problem relieving the pressure by tapping the pin (or ball) on the male connectors or using a drift pin on the female connectors, but as has already been said, you can take a couple of wrenches and loosen the fittings to relieve pressure. And I don't mean to be facetious, but are you holding the locking ring back on the female connector while you push it onto the male connector? If not, that's your problem.
To: Russ, Bird & Gene,
The suggestion made by Gene worked like a charm! I loosened all the fittings at the cylinder connections and enough fluid weeped from all those connections to allow the male connectors to marry right-up to the females. I got it mounted and prepared for the job I had contracted for in last moment! Thanks to all for their valuable input! That's what makes tihs forum GREAT!
   / 7308 Hoses Will Not Connect #6
Russ and Bird had the good suggestions...I'll take the credit.
Thank you very much.
Gene
   / 7308 Hoses Will Not Connect #7
We don't care who gets the credit as long as the problem got solved./w3tcompact/icons/wink.gif
   / 7308 Hoses Will Not Connect #8
Aw Shucks!!! /w3tcompact/icons/blush.gif
   / 7308 Hoses Will Not Connect #9
Well Russ, you can't win 'em all! But you come up with so many winners normally anyway, you can let one slip by once in awhile without feeling too bad! /w3tcompact/icons/wink.gif/w3tcompact/icons/grin.gif
P.S. Do you get private messages? I hope so - 'cause I sent you one! /w3tcompact/icons/grin.gif
Yale Veracitor 135VX Yale 12,150lb Forklift (A50322)
Yale Veracitor...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
