7308 FEL Quick Disconnect Size?
   / 7308 FEL Quick Disconnect Size? #1
F_22
Outside Atlanta, Georgia
NH TC33D HST
Anybody know what the nominal size of the quick disconnects on the 7308 loader are? I'm making a pressure gauge setup. I bought a 3/8" at northerntool cause it looks like the right size but the male end won't quite fit in the female on the tractor. Could it be 1/4" or are there different styles like with pneumatic couplers?
   / 7308 FEL Quick Disconnect Size? #2
Ah, I can't find the Pioneer web page right now, but here is a sampling of their products:
http://www.dultmeier.com/search.asp?advanced=yes&manu=PIONEER
There are a dozen or so different tip types; some are compatable, some are not. You need to look at your coupler & you will find the number stamped on it, and find a cross compatable type. NH generally uses types compatable with universal, or standard, Pioneer type, but you never know, & don't know what you woulda got from the store?
--->Paul
   / 7308 FEL Quick Disconnect Size? #3
I bought one at the local hydraulic shop. It was a male ISO 7241-1 Series A, 3/8" NPTF. It worked like a charm. If it's not a series A it won't fit.
   / 7308 FEL Quick Disconnect Size? #4
Thee is a huge difference between a 1/4 NPT and 3/8 NPT connectors. Sitting side by side, the 3/8 is significantly larger. You probably will need a 3/8 NPT male coupler.
DavidJ is correct:
Parker part no. 6602-6-6
Aeroquip part no. 5602-6-6S
$13.49 at NH dealer, $7.30 at Grainger.
Root Rake Skid Steer Attachment (A56857)
Root Rake Skid...
SHOPBUILT 3PT LAY-BY RIG (A52708)
SHOPBUILT 3PT...
Flatbed Truck (A55973)
2009 Ford F-150 Crew Cab Pickup Truck (A56858)
2009 Ford F-150...
Mower Edger Attachment (A55974)
Mower Edger...
(4) 225/65R17 USED TIRES (A58374)
(4) 225/65R17 USED...
