7308 FEL Quick Disconnect Size?
   / 7308 FEL Quick Disconnect Size? #1
F_22
Bronze Member
Outside Atlanta, Georgia
NH TC33D HST
Anybody know what the nominal size of the quick disconnects on the 7308 loader are? I'm making a pressure gauge setup. I bought a 3/8" at northerntool cause it looks like the right size but the male end won't quite fit in the female on the tractor. Could it be 1/4" or are there different styles like with pneumatic couplers?
   / 7308 FEL Quick Disconnect Size? #2
Ah, I can't find the Pioneer web page right now, but here is a sampling of their products:
http://www.dultmeier.com/search.asp?advanced=yes&manu=PIONEER
There are a dozen or so different tip types; some are compatable, some are not. You need to look at your coupler & you will find the number stamped on it, and find a cross compatable type. NH generally uses types compatable with universal, or standard, Pioneer type, but you never know, & don't know what you woulda got from the store?
--->Paul
   / 7308 FEL Quick Disconnect Size? #3
I bought one at the local hydraulic shop. It was a male ISO 7241-1 Series A, 3/8" NPTF. It worked like a charm. If it's not a series A it won't fit.
   / 7308 FEL Quick Disconnect Size? #4
Thee is a huge difference between a 1/4 NPT and 3/8 NPT connectors. Sitting side by side, the 3/8 is significantly larger. You probably will need a 3/8 NPT male coupler.
DavidJ is correct:
Parker part no. 6602-6-6
Aeroquip part no. 5602-6-6S
$13.49 at NH dealer, $7.30 at Grainger.
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2024 John Deere 331G Skid Steer w/ WARRANTY! (A59213)
2024 John Deere...
Universal Mount Equipment Seat W/ Headrest & Arm Rests, and Seat Belt (New/Unused) (A59225)
Universal Mount...
2022 International MV607 Terex XTPRO56 56ft. Insulated Forestry Chipper Bucket Truck (A55973)
2022 International...
2021 Toyota Corolla (A56859)
2021 Toyota...
