73 massey 135 3pt lift work up and down. Had a disk on it. Loaded on trailer then would not work
   / 73 massey 135 3pt lift work up and down. Had a disk on it. Loaded on trailer then would not work #1
Nick21
73 massey ferguson 135
I hear the pump kick in on up position. Bur no movement. Can pick up with hands no resistance. Stays down. Help please
   / 73 massey 135 3pt lift work up and down. Had a disk on it. Loaded on trailer then would not work #2
Usually the rockshaft piston o ring seal needs replacement
   / 73 massey 135 3pt lift work up and down. Had a disk on it. Loaded on trailer then would not work #3
Is the handle with the round ball (draft control, outer lever) all the way back? If the draft control is not all the way back the square knob handle (position control, lever closer to you) will not work right.
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
2010 SHOPBUILT POWER SWIVEL TRAILER (A50854)
2010 SHOPBUILT...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2012 GENIE S-60X MANLIFT (A50854)
2012 GENIE S-60X...
