Mowing 7264 PTO / mower not working
/ 7264 PTO / mower not working #1
txkwgrl
OK, Here is the scoop.
I have just inherited this tractor and it came with mower deck attatched, as well as a shredder and a box blade. The problem is it did not come with any info, books, etc... I can raise and lower the deck, the hydraulics work for the shredder and blade, basically I can do everything but what I need to do...that is I can not get the mower blades to engage nor does the rear PTO turn. I can turn the PTO with my hand eassily and I have looked under the mower but cannot see the PTO turn anywhere...am I just stupid, is there a trick or???? As far as I have been told it worked fine when it was last used and was kept inside, appears in excellent shape and is clean. HELP PLEASE!!!
/ 7264 PTO / mower not working #2
You might be able to download the owners manual from the CC site if you have the serial number. You did engage the PTO levers? There should be one for the mid and a separate one for the rear.
