72" MMM Rear Discharge Gator Blades
   / 72" MMM Rear Discharge Gator Blades #1
Boomer 1
I've read a lot of the threads about the mowers and would like to try a set of GATORS. Does anyone have the part # for the blades. I have also cut about an 1 1/4" off of the the discharge area, this has helped to improve the clipping distribution. Any input is appreciated.
   / 72" MMM Rear Discharge Gator Blades #2
Boomer 1,
I do NOT have these blades yet, but have been wanting to give them a try myself. I asked this same question a while back.
I think Thrci has them on his 72" side discharge deck and hazmat has them on his 60" rear discharge deck.
P/N for the 60" is: AUB163680
P/N for the 72" is: AUB163681
Hope that helps,
CBox
Cbox
Are these CNH part #'s or Gator part #'s? Thanks for the reply.
   / 72" MMM Rear Discharge Gator Blades #4
Last I checked you can not buy the Gator Blades for the New Holland from Gator?? You can only buy them from CNH. Which was fine because when I bought mine, I now have two sets, they were cheaper from CNH than the listed blade prices on Gator's web page.
New Holland also has a "High Lift" blade option also that may work as well as the Gator's.
murph
   / 72" MMM Rear Discharge Gator Blades #5
Boomer 1 said:
Cbox
I just picked up a spare set to swap out when sharpening blades. I have the 72" rear discarge and the part number given is a CNH. My dealer stocks these and only uses them on thier 914A MMM decks. Cost was about $19 and change from the dealer (each).
The blades work very well. Two things you must do to ensure a good even cut and distribution is to keep the blades relatively sharp, sepecially the ends since there is only 1/2" of overlap and keep the underside of the deck scraped clean. It is a pain but is worth it.
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
IRONCRAFT 84" ROTARY MOWER (A51247)
IRONCRAFT 84"...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
