72" MMM Rear Discharge Gator Blades
   / 72" MMM Rear Discharge Gator Blades #1
Boomer 1
I've read a lot of the threads about the mowers and would like to try a set of GATORS. Does anyone have the part # for the blades. I have also cut about an 1 1/4" off of the the discharge area, this has helped to improve the clipping distribution. Any input is appreciated.
   / 72" MMM Rear Discharge Gator Blades #2
Boomer 1,
I do NOT have these blades yet, but have been wanting to give them a try myself. I asked this same question a while back.
I think Thrci has them on his 72" side discharge deck and hazmat has them on his 60" rear discharge deck.
P/N for the 60" is: AUB163680
P/N for the 72" is: AUB163681
Hope that helps,
CBox
Cbox
Are these CNH part #'s or Gator part #'s? Thanks for the reply.
   / 72" MMM Rear Discharge Gator Blades #4
Last I checked you can not buy the Gator Blades for the New Holland from Gator?? You can only buy them from CNH. Which was fine because when I bought mine, I now have two sets, they were cheaper from CNH than the listed blade prices on Gator's web page.
New Holland also has a "High Lift" blade option also that may work as well as the Gator's.
murph
   / 72" MMM Rear Discharge Gator Blades #5
Boomer 1 said:
Cbox
I just picked up a spare set to swap out when sharpening blades. I have the 72" rear discarge and the part number given is a CNH. My dealer stocks these and only uses them on thier 914A MMM decks. Cost was about $19 and change from the dealer (each).
The blades work very well. Two things you must do to ensure a good even cut and distribution is to keep the blades relatively sharp, sepecially the ends since there is only 1/2" of overlap and keep the underside of the deck scraped clean. It is a pain but is worth it.
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
5" & 6" CHANNEL IRON UP TO 20' LONG (A51247)
5" & 6" CHANNEL...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2024 JOHN DEERE CP 770 LOT IDENTIFIER 21 (A53084)
2024 JOHN DEERE CP...
