72 ford 4000 heater plug
   / 72 ford 4000 heater plug #1
Con4000
Co Tyrone
72 ford 4000
Hi all, I have a heater plug in the back of the manifold of my ford 4000, it has a cable from the key switch and a pipe that carries diesal from the tank, I'm just wondering what is the correct lay out for the pipe work, in my ford there is a small fuel resiviour that has 3 ports, 1 on top that returns to tank and 2 on the bottom, one is the return from the injectors and the other seems to b running to the Heater plug although it never seems to have any diesal in it, is this resiviour needed or how should it be connected properly
   / 72 ford 4000 heater plug #2
It sounds to me like yours is corect, after the last injector the bleed off tube goes to the reservoir to keep it full then dumps back to the tank or back in the fuel filter housing (depending on the model) Fuel flows by gravity down to the thermostart element/valve mounted in the intake. After the element has reached it's set temperature it opens and allows the fuel to flow onto the element and ignite.
this is out of one of my industrial Ford manuals, but the idea is the same -
2014 International Durastar 4300 Terex BT3063 63ft 15 Ton Crane Truck (A50323)
2014 International...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
John Deere L125H Skidloader (RUNS) (A50774)
John Deere L125H...
2008 GMC C7500 Altec LRV55 55ft Forestry Chipper Bucket Truck (A50323)
2008 GMC C7500...
