72" bent bucket edge (need advice)
   / 72" bent bucket edge (need advice) #1
Honey Badger
SW VA
2012 Kioti DK45se
Hello everyone, bought this tractor and the bucket front edge is bent! Looks like a tooth bar must have been installed on it at one time and a thooth must have gotten caught on something but not really sure! Any advice would be great on what could do to repair or replacing it.
Thanks in advance
   / 72" bent bucket edge (need advice) #2
Heat and a big hammer you need something solid and flat to rest the bucket on then pound away....
   / 72" bent bucket edge (need advice) #3
Flip it upside down and use a sledgehammer, you'll be surprised how easy it moves. I fixed my dad's in about 20 minutes. I used wood blocks as a underside support.
   / 72" bent bucket edge (need advice) #4
Some heavy backup material and a stout machinists vice to pull it back straight. You can put a socket and torque bar on the hex drive of many of those vices. Is there a welded on cutting edge? Hard to tell from the pictures.
Thanks guys, I'll try your advice! I do understand backing it up good is everything!
   / 72" bent bucket edge (need advice) #6
If you have a piece of railroad rail, that would be a great underside support.
   / 72" bent bucket edge (need advice) #7
You might be able to put a big piece of 1/2 inch steel plate under it and beat it with a heavy sledge. I think that will save your concrete and it will flatten out.
I have a 13 pound sledge I use. It was my grandfathers.
   / 72" bent bucket edge (need advice) #8
For general straightening I would just try sledge hammer on long irregularities with maybe wood under it to protect pavement under edge... ON ouchie on right lots of heat... Metal is stretched so it is not really going to be happy going back into original shape...
Dale
All good advice guys! Got something out of ever reply - Thanks again
Thought I would add some more pictures, Industrial Toys - here's the factory welded cutting edge. I did hit it with a sledge hammer before, but did not back it up good enough. but was not at a place to do better job! I also want to look into the vice you suggested.
I think heating it is a must when getting it back close to strait again.
2016 F-550 Stake Body 12FT Flatbed Truck (A50323)
2016 F-550 Stake...
New Giyi Dingo Backhoe (A50774)
New Giyi Dingo...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2019 Chevrolet Cruze Sedan (A50324)
2019 Chevrolet...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A50322)
2014 JLG G12-55A...
