72” vs 84” Tiller
   / 72” vs 84” Tiller #21
Many tillers can be mounted slightly offset to follow one wheel, and it isn't too bad to work that way.
Consider maneuverability if you are planning to till between rows of trees, or around trees. And, of course, roots.
How hilly is your property? Do you need the wheels set out wide?
   / 72” vs 84” Tiller #22
You have to decide how much money you want to spend before you do anything.
Investing in a heavy 3 point hitch mounted disc harrow with ripping discs and
smoothing discs may be a better option for you.
   / 72” vs 84” Tiller
Why is this a bad purchase?
   / 72” vs 84” Tiller #26
No doubt China built with no replacement parts availabile.
   / 72” vs 84” Tiller
What else needs to be replaced on a tiller?
   / 72” vs 84” Tiller #28
Tiller tines, bearings and the roller chain if used if it is not gear driven.
An Italian disc plow from SICMA and a small disc harrow from SICMA would work well too.
Contact Ken Sweet at Sweet tractors and ask about them as he is a SICMA dealer.
   / 72” vs 84” Tiller #29
Tines
   / 72” vs 84” Tiller #30
A nice disc harrow takes a lot less hp and is so much faster
True to a point. Especially on ground that has been worked in the last few years.
We had horses running on several acres for years. I tried a disc with serrated on the front , and even mounted weights and rail road rail for extra weight. It would barely scratch the surface. I finally ended up buying a tow behind JD 3 bottom plow with hydraulic lift to really break the ground. The 84" tiller would also break it up but was a bit of a ride on the initial pass.
We had a Howard years ago and that thing took a beating and just kept on going. I have an 84" chinese tiller and even though it is heavy built have broken several parts of it.
2017 KUBOTA SVL95-2S SKID STEER (A52707)
2017 KUBOTA...
2025 Star EV Capella Low Speed Electric Cart (A55853)
2025 Star EV...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2002 Bobcat 763 Compact Skid Steer (A55314)
2002 Bobcat 763...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
