71M MIG Wire
/ 71M MIG Wire #1
RNeumann
Elite Member
North Idaho
Mahindra 1538
Anyone tried the 71M wire for MIG? I do mostly tractor/farm type fab and repairs. This seems like a good fit.....on paper anyway. Just wondering if anyone has used it and could compare it to anything else. Maybe it’s more
Like XXX stick or it’s not worth it for a homeowner or it’s the greatest thing to come along in the last 10 years!?!?
I’d probably try a 10# spool of the .035.
/ 71M MIG Wire #2
I have limited experience with 71M but I do like it. I leave a feeder permanently set up with .045. Writing down the settings once you get it dialed in is a must for me though.
The pros will be able to better comment on worm tracks etc......
/ 71M MIG Wire
Did you find it was fairly easy to use once it was setup? Anything special?
/ 71M MIG Wire #4
I did struggle (that's just me though) with set up but it ran nice. Spray-like transfer.. Smooth. It almost made me look like I knew what I was doing.
Buy the smallest roll (prob 10#) and try it. You probably don't even have to buy a different shielding gas from what you have.
/ 71M MIG Wire #5
No Pro here either but the 71M like all of it's competitors is just dual shield flux cored wire that is nearly a direct replacement for 7018 stick rod. I see a lot of it formulated to run on CO2 or 75/25 and most applications are on heavy plate like dozer parts, buckets and mine equipment. Multi pass capable, comes in large sizes and works ok on mill scale. I don't like the smoke or the slag that it produces though so I never use it. High deposition rates and larger size wires are a big draw. Some big shops like shipyards and mine manufacturers are starting to migrate back to hard wire now that Pulse is gaining in popularity.
/ 71M MIG Wire
I have an older Lincoln 175a MIG machine- (I also have a stick and TIG). I added a trailer receiver to my Box Blade the other day and that got me thinking about it. I ground the paint off etc so my prep was OK. It’s obviously no laboratory though. My MIG worked fine but I thought I’d give this a try- maybe bring a little new life to the old machine. Sounds like for the cost of a spool I should give it a try.
/ 71M MIG Wire #7
The Kobelco, Hobart, or ESAB version is much nicer to run. Slag is thin and an easy cleanup. Better values than E7018.
I am too cheap. I use .035 ER70S-6 with 75/25 for all my welding. For 3/8" and thicker, I have used 98/2 for more penetration.
/ 71M MIG Wire #8
This thread is a just another of many examples of why I subscribed to the Welding forum on TBN. Now I see all the new threads and can learn the 'why' for various welding applications. And from both a professional and layman's view.
2024 FOREST RIVER 6X10 ENCLOSED TRAILER (A63569)
2024 FOREST RIVER...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
John Deere 4230 Tractor w/ Loader Bucket and Hay Spear (A64047)
John Deere 4230...
2024 Schulte 5026 Batwing Rotary Cutter (A63118)
2024 Schulte 5026...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2018 Dodge 5500 Bucket Truck 4WD (A63118)
2018 Dodge 5500...
