Feb 27, 2023 / 7040 relief valve #1 D DJM1591 New member Joined Feb 9, 2023 Messages 19 Tractor Kubota M7040 4WD Utility Tractor $475.00 . thats just theft. The bad thing is when you have to have one there is no alternative.
Feb 28, 2023 / 7040 relief valve #2 Tx Jim New Member Joined Jan 26, 2007 Messages 10,392 Location Coyote Flats,Tx Tractor JD 4255/Kubota M7040 HDC Due to the fact I own a M7040 would you mind revealing where this $475 relief valve is located on a M7040?
Feb 28, 2023 / 7040 relief valve Thread Starter #3 OP D DJM1591 New member Joined Feb 9, 2023 Messages 19 Tractor Kubota M7040 4WD Utility Tractor Tx Jim said: Due to the fact I own a M7040 would you mind revealing where this $475 relief valve is located on a M7040? Click to expand... On the rear of tractor above the lift arms. If you have rear remotes it is just in front of those .
