7020 ingersoll case
/ 7020 ingersoll case #1
jdwinters
norton ma
7020 ingersoll case
i have a 7020 ingersoll case tractor it does't seem to have the power it used to have, motor runs good. the pump sounds like it has air in it , oil level is where it should be any ideas
/ 7020 ingersoll case #2
Welcome and good luck with your 7020.
/ 7020 ingersoll case #6
How many hours are on this tractor?
Is this a loader tractor or a loader/backhoe tractor?
Have you owned it since it was brand new?
How often have you changed out the hydraulic fluid since you have owned it?
What brand of oil and what weight/grade of oil have you used in the hydraulic system?
Where do you feel it is lacking in power? Ground speed? Or loader function?
/ 7020 ingersoll case #7
Welcome to TBN. If it is a hydro it could be bypassing hydraulic pressure it will not pull as well as it is not building proper hydraulic pressure. Just a thought as you said that the pump sounds different. I would check the pressure to see if it is in bypass. It would help if you could post pics of the machine and some more info.
2025 LandHonor LHR-SBC19 19 Gallon Portable Sand Blasting Cabinet (A64194)
2025 LandHonor...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
JOHN DEERE 5510 TRACTOR (A64278)
JOHN DEERE 5510...
2022 EZ-GO ELITE...
2022 BOBCAT T66 R-SERIES SKID STEER (A65053)
2022 BOBCAT T66...
