7010 cab engine
/ 7010 cab engine #1
jwcinpk
Veteran Member
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
In researching the 7010 cab I started checking specs against the 7520. Is this the same engine just a different hp rating? Maybe tweaked just a bit? Engine is same cubic inches and compression ratio. I gather they are both turbo. I'm almost ready to try to broker a deal the only thing holding me back is TYM is set to remove this tractor from it's lineup so I assume it will be gone from Mahindra's too. I wish I knew more about the engine and it's future. Is Mahindra set to release something new in the 70 - 80 hp cab tractor line since I assume they will no longer get the 700. In other words is there gonna be something better worth waiting for? /forums/images/graemlins/confused.gif
/ 7010 cab engine #2
Joel,
The engine in the 7010 is pretty much the same as the 7520. If TYM discontinues supplieing the tractor to Mahindra I am sure Mahindra/TYM will continue to supply service & parts for the tractor. I don't know what Mahindra's plans are, as far as a cab tractor is concerned, if the 7010 was discontinued.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia, NY 14020
585-343-0770
/ 7010 cab engine
Now I understand more about why Mahindra did not outsource the engine in this tractor like TYM and Montana. I geuss they feel pretty comfortable with the engine they have so why go pay for another one. I am curious though exactly what the difference is in the engines. Why the 72hp rating and not the 75hp rating? Perhaps so as not to offend the supplier that is putting a 72hp engine in theirs. Now I geuss I should be asking the 7520 owners how they like the engine in their tractors!
/ 7010 cab engine #4
Should be pretty bullet proof. Lower the compression ratio from 19.4 to 18.4, ad a small turbo with limited boost and Voila! 12-15 HP over the 6000. I imagine that that difference is that the 7510's boost is a tad higher than the 72....BobG in VA
Hesston 3717 4 Basket Hay Tedder (A66408)
Hesston 3717 4...
Wolverine 84" Quick Attach Snow Push (A66285)
Wolverine 84"...
2015 John Deere 35G Mini Excavator (A62613)
2015 John Deere...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2015 PETERBILT 579 (A65643)
2015 PETERBILT 579...
10.5' Telescoping Ladder (A66408)
10.5' Telescoping...
