7010 by TYM?
/ 7010 by TYM? #1
jwcinpk
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
Is the 7010 cab made by Mahindra or TYM? I see it is identical to the new Montana 70 series. What's the difference? Montana has Deere engine while 7010 has Mahindra? What else?
/ 7010 by TYM? #2
Typically the Mahindra 10 series is made by TYM but may have different engines. It appears the Montana is identical to the TYM model (same engine)
Mahindra 7010 Cab
TYM-USA T700
Montana 70 Series
They look identical but the engine specs are different. I think they also source the attachments differently.
It looks like the Mahindra has a bigger engine but I'm not sure who makes it (one of the dealers here can probably provide that). The TYM has a Deere engine but the PTO specs are pretty much the same except that Montana lists the PTO HP a little lower for the same engine as the TYM. Personally, I haven't found much reliability in the manufacturer specs for tractors.
They all look pretty similar. Sounds like a great bargaining opportunity to play some dealers off each other! /forums/images/graemlins/wink.gif
/ 7010 by TYM? #3
I believe that the engine is actually built by Mahindra. The specs are identical to the 6000 engine (displacement/# of pistons, etc), but the compression ratio is 18.4 to 1 vs. 19.4 to 1. I believe they used a small turbo unit on this engine to to boost HP from 59 (6000) to 72 (7010). Any takers on this? BobG in VA
/ 7010 by TYM? #5
Does that mean that us 00 owners could add that turbo to get even more power!!!! HA HA HA!!!!
To be honest I don't know what I would do with more power. /forums/images/graemlins/smile.gif It's already a tank.
/ 7010 by TYM? #6
I agree with your TANK assessment. Suffice it to say your Mahindra engine, if turbo capable, should last many thousand hours as a normally aspirated unit. BobG in VA
/ 7010 by TYM?
The specs are a little plain. I don't see any mention of a turbo. It is rated at 2hp more than the others. Undoubtedly the Mahindra dealer will give more in trade for the 6000. A turbo, In my opinion that's what the 6000 needs. My tractor (6000) pulls good and hard it could just breathe a little better on the low end to help it pull better. It would help in thick grass with the 8ft disc mower.
F-250 SuperDuty (A63689)
F-250 SuperDuty...
(2) Tractor Wheel Weights (A65640)
(2) Tractor Wheel...
Luck Now XLR 4750ST (A64126)
Luck Now XLR...
(2) Firestone Tires (A65640)
(2) Firestone...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2026 X Star Fuel Trailer (A64127)
2026 X Star Fuel...
