7 way vs 6 way trailer plugs
   / 7 way vs 6 way trailer plugs #1
bdog
Elite Member
Texas
John Deere 6130M
Years ago it seemed like the six way round metal trailer plugs were the most popular. Now it seems every truck or trailer I buy has the big plastic seven way. I don't need the functionality of the seven way but am thinking of changing just to be more standard and to quit having to change every thing I buy. Do the seven way connectors work well and hold up over time?
   / 7 way vs 6 way trailer plugs #2
around here, the 6 way are usually found on ag trailers .. and also on discount trailers. i guess the 1$ they save when buildingthe trailers makes a difference int hat 6 vs 7 debate. anything with no brakes is getting the 4 flat.
I used to keep a 6 way on the truck for a couple ag trailers, but now have everything 7 and use a 7 to 6 adapter if AI need to use my ag trailer. when the 6 ways on the trailer wear out eventually.. I'll upgrade to 7 just because...
   / 7 way vs 6 way trailer plugs #3
I work with trailers every day, maybe 75 of them a year. 99.9% are 7 pin. I have not delt with a 6 pin since about 2004 and the first thing I did with it was cut off the 6 pin and put on a 7. Reverse is what you gain with a 7 pin and its necessary for any trailer with disc brakes which are now the standard in the marine industry.
Chris
   / 7 way vs 6 way trailer plugs #4
The 7 pin seem to hold up quite well and make a good connection due to the large flat contact surfaces.
2013 Kenworth T800 T/A Dump Truck (A53117)
2013 Kenworth T800...
2025 K2215 UNUSED Portable Restroom and Shower (A53117)
2025 K2215 UNUSED...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2005 TerraGator 8104 (A53473)
2005 TerraGator...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
Unused 2025 Electric Cart (A51694)
Unused 2025...
