7 tooth spring ripper-cultivator-chisel
   / 7 tooth spring ripper-cultivator-chisel #1
paulsharvey
Super Member
Hawthorne, Fl
Kioti CK2610 HST
Anyone able to ID this. It looks like a cross between a very light chisel plow and a heavier cultivator, or maybe a "pasture rejuvenator".
I'm guessing around 300 lbs; just over 7 foot wide; 7 dual spring loaded teeth.
Feels like old school Massey or Ford-Dearborn; but not tag, no sticker, no serials, or ID, and either might have been red, or red iron oxide primer, or maybe just rusty metal; no clearly definable paint left.
Paid $100 for it. We'll, paid $140 for it and a 4 ft bushhog, that is probably just a waste... Bushhog is a New Holland
Bush hog pictures too
Kinda looks like a Dearborn 13-1, without the depth control disc in the center front?
I'm kinda leaning towards it looks a lot like a MF 38, or the EA from this video.
Regardless of the exact model, I'll tell you, when all 7 shanks are down, 12" or so, it's more than my CK2610 wants. It does do a good job working roots/wood trash upto the surface to pile and burn.
   / 7 tooth spring ripper-cultivator-chisel #5
The All Purpose Plow may be a Leinbach.
This guess based on shovels mounted on the tines.
   / 7 tooth spring ripper-cultivator-chisel #6
Light weight chisel plow. Tons of them around here. I have one sitting in my implement lineup that hasn't been used in years. I have a big 9 point chisel that I use. It will go at least twice as deep as that one. Mine is a Massey.
So, I don't know that I will ever find out what the original brand name was; but it looks like Lienbach made the EA model; which appears identical to the Bushhog branded one; and I have found a parts diagram for the Bushhog model. I'll have to check sprung diameter, and wrap count, but I think I have a good starting place
It looks like it matches the Bushog APP85-7.
   / 7 tooth spring ripper-cultivator-chisel #9
Paid $100 for it. We'll, paid $140 for it and a 4 ft bushhog, that is probably just a waste... Bushhog is a New HollandView attachment 1641278View attachment 1641315View attachment 1641536View attachment 1641566
I have a 9 shank model just like that only newer. It is called a Fred Cain all purpose plow. It’s really good for deep ripping.
   / 7 tooth spring ripper-cultivator-chisel #10
Looks like the only thing you can salvage from the brush hog is the 'c-clamp'
Two Post Car Lift (A50120)
Two Post Car Lift...
2023 John Deere 6155M Tractor (A53485)
2023 John Deere...
2017 Caterpillar 326FL Hydraulic Excavator (A53421)
2017 Caterpillar...
Hose Reel (A55758)
Hose Reel (A55758)
Kubota BX25D (A53317)
2004 Mack CV713 Granite Fuel and Lube Truck (A55852)
2004 Mack CV713...
