7 Pole Round Trailer Connector
   / 7 Pole Round Trailer Connector #1
pyro29
Eastern CT
Mahindra 4035 PST
After reviewing the wiring diagram in the operations manual I noticed that there is nothing in the print about the 7 pin trailer connector. Does anyone have a copy of this portion of the diagram?
Thanks
   / 7 Pole Round Trailer Connector #2
It is a European 7 pin if that helps?? If you are looking for what the pins are, just google 7 pin.
No, I can check the pins with a test light, I was more looking for a diagram to see where the power (Aux) feed came from, the wire size, and to see if and how it was protected from overload.
   / 7 Pole Round Trailer Connector #4
if only they had a constant power run to it. :((((((
   / 7 Pole Round Trailer Connector #5
Thanks
I have a 7 pin round plug on my tractor (not Mahindra) but if you have the same it should be wired the same. Easy enough to check with a test light. Mine has power on one pin when the key is on. It is on a 15A circuit on my tractor.
   / 7 Pole Round Trailer Connector #6
Use a test light to identify the aux power pin. Short it out. Check the amperage of the blown fuse.
:cool2:
   / 7 Pole Round Trailer Connector #7
I don't think I would just short it out to find the fuse. Your tractor probably has "electronics" in it and they are expensive to replace and **** to troubleshoot, just remove the gage panel and look at the back of it to see for yourself... Follow the wires or use your owners manual to eliminate the large majority of fuses. Pull the fuse you think might be the one and check for voltage. Shouldn't be but one or two to choose from.
   / 7 Pole Round Trailer Connector #8
I don't have my tractor here to test, but my guess is that the fog pin has 12v all the time.
   / 7 Pole Round Trailer Connector #9
I converted mine to a standard 7-way.
   / 7 Pole Round Trailer Connector #10
Did you happen to write down how you did it? Wire color to pin #? Was there plenty of slack in the wires to take the plug off and mount up the new one?
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
2019 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
UNUSED AGT QK20R EXCAVATOR (A51243)
UNUSED AGT QK20R...
VEGETABLE TRAILER (A51244)
VEGETABLE TRAILER...
