7' Hydraulic york rake
/ 7' Hydraulic york rake #1
RobbieBones
New York
Can I run a 7' Hydraulic york rake behind a B21? If not I will cut it down to 6'?
What would I need for the rear controls the rake is plumbed already.
Rob
/ 7' Hydraulic york rake #2
Hi Rob,
I run a 6' york rake behind my B21 with no issues. Its not hydraulic tho. Your B21 has the remote hookup for the BH so you will need a valve off of that to tilt/angle the rake. Presume this is for a power angle on the rake?
I would not cut it down unless you really need to as the B21 should handle it OK doing grading and dirt work. If you are doing a lot of rock/stone grading uphill etc then you might be pushing it at 7' but try it first - no harm done.
Carl
Yes it is for dirt that has plenty of rocks/stones on mostly flat land some mild slopes. Not really looking to do stoned driveways but you never know.
Rob
/ 7' Hydraulic york rake #4
Rob,
You need a two position valve in the supply line (the top on I think on the B21) and a return line from the rake cylinder. Depending on what the rake has on it now - it is just two hoses and a cylinder or does it have a valve?
If no valve then you need to set up a valve body off the B21 Hyd connection pressure side to direct the flow in/out on the cylinder then the return from the valve body. This is the same type setup concept used on a Hyd wood splitter. The valve bodies are about $75 range then hoses and fittings.
Carl
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
2022 EZ-GO ELITE...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2019 TAKEUCHI TL12V2 SKID STEER (A64279)
2019 TAKEUCHI...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
