7' Finishing Mower with L3130
   / 7' Finishing Mower with L3130 #1
Jarrett
Holden, Louisiana
Kubota L3130DT
Does anyone use a 7' finishing mower with a 3130? I've been shopping for a finishing mower and was planning to get a 6', but I was wondering how a 7' performed with the 25 PTO HP of a 3130.
   / 7' Finishing Mower with L3130 #2
When Our company jumps from 6 ft to 7 ft, the weight jumps 300 pounds and it is a monster. Our 6 ft "First Choice" in Orange color and rear discharge is $1395. I would definitely stay with a 6 footer. Ken Sweet
   / 7' Finishing Mower with L3130 #3
No, not a 7 footer on a L3130 but I run a Woods 6 footer on my B3200 and it doe a terrific job. It is quite heavy and I do know It's back there. I believe between the B3200 and your L3130 the horse power is pretty close although I know the L weighs in more. The 6 footer might be the choice for you.
DevilDog
   / 7' Finishing Mower with L3130 #4
I have to agree with everyone else the 7 foot is too big. I had a 6 foot Land Pride RFM on my B7800 which I think was 23 Pto Hp and it did fine , but the 7 foot on my L3940 works it pretty good.
I kinda figured a 7' would be too much. Would that also apply to a flail mower? If I decide on a flail should I stick to a 6' also?
   / 7' Finishing Mower with L3130 #6
My L3130 doesn't know my 6' RFM is there, I would think it would handle a 7' rather easy, but I don't have one to say for sure.
   / 7' Finishing Mower with L3130 #7
I run a 7 foot Land Pride finish mower on my L4200 Kubota. Perfect fit... I have also ran right at an 8 foot flail.
The best gage as to how much you should normally run with is: If you are usually using near 100% of your HP you are over loaded...
You should be able to throttle up from rated PTO speed while cutting whatever you would normally cut. If you can not increase your rpm... you are going to be running too close to your max sustained load.
I think a 6 foot finish mower would most likely top out what you would want to continually subject your tractor to. KennyV
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
2004 Nissan Armada SUV (A50324)
2004 Nissan Armada...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2025 Kearney 102"x36' Trailer (A50120)
2025 Kearney...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
