Rotary Cutter 7' Bush Hog vs Woods rotary mower
   / 7' Bush Hog vs Woods rotary mower #1
big bubba
Elite Member
arkansas
M8540
looking to buy either 297 series Bush Hog or Woods Brush Bull extreme (bb840x) (both 7') rotary mower....both seem comparable on specs/weight.....Woods around $300 more. your preference & why on either? how does the quick change blade pin work on the Woods? thanks bb
   / 7' Bush Hog vs Woods rotary mower #2
With bush hogs good name at stake, and Wood's reputation for gearbox trouble on their larger mowers, I would have to seriously consider the Bush Hog's mower.
David from jax
thanks sandman, just the feedback I'm looking for.....am leaning in the same direction myself though wasn't aware of gearbox issues w/woods. bb
   / 7' Bush Hog vs Woods rotary mower #4
If I remember correctly, Farmwithjunk is the one that mentioned gearbox problems with the larger batwing type mowers from Woods. However, if they can't build a gearbox for a batwiing, what makes you think that the "heavy duty" mowers are going to be any better. Get my drift???
I am just passing on a general impression, from reading a few posts on TBN.
Just got back from my 35th class reunion in SW Arkansas...
David from jax
   / 7' Bush Hog vs Woods rotary mower #5
BB not sure if you have a Brown dealer in your area, but if you do I would take a look at the Brown 484 model or the tougher 684 model it's a beast. These aren't the tree cutter versions, just some mighty tough cutters.
I'm not a real big fan of 7' cutters....... but they are cheaper then a twin spindle 8' model.
   / 7' Bush Hog vs Woods rotary mower #6
I won't even consider owning another Woods mower. And it was a BB840 that prompted my poor opinion of their product(s). I had issues with the gearbox, paint, 3-point hitch framework, and Woods failure to honor warranty. Less than 2 seasons of use and it was literally JUNK.
The Bush Hog 28X and 29X series mowers are UNDER rated. They meet or exceed my expectations of a heavier duty rated mower. I've logged 4-1/2 seasons of use on the Bush Hog mower (287) that replaced the Woods BB840. It still runs like the day I first bought it.
IMHO, it's not even a question which one I'd buy.
   / 7' Bush Hog vs Woods rotary mower #7
Thread's a little old, but I got to defend my Brush Bull! I've owned a BB600 for 6 or 7 years now and haven't had one bit of trouble out of it. I've punished it working in the woods a lot and it stands up to the test every time. I can use it to knock down and chew up hardwoods in the morning and then mow the lawn in the afternoon:D (I don't use it to mow our lawn, but the cut quality is good enough to do it). Mine sites out in the weather and the paint is holding up great.
I've owned and operated other cutters, but this Brushbull is by far the best!
I don't really know about these problems a few other guys have had, but mines been flawless and I haven't babied it at all.
   / 7' Bush Hog vs Woods rotary mower #8
I have a woods ms8.30. Bought new in 2019, I have it hooked up to a 60hp tractor. It has had a bad vibration since new. Not a wobble when you first engage the pto but it starts vibrating all of a sudden while cutting and is prone to it unless it is adjusted perfectly where it wants to be then it still may. Woods said that is "normal on a twin spindle". I would not purchase another woods cutter in my life. This is my third cutter by the way.
   / 7' Bush Hog vs Woods rotary mower #9
My Woods BB-72X has been trouble free for 15 years. Now I have a leaky seal but it’s a cheap fix
   / 7' Bush Hog vs Woods rotary mower #10
I have had both brands. I think I prefer Woods , but not by much.
2370 (A58376)
2370 (A58376)
John Deere Metal Sign (A57454)
John Deere Metal...
TANK MANIFOLD (A58214)
Pelican Statue (A57149)
Pelican Statue...
Caterpillar 1430D Backhoe Loader (A57148)
Caterpillar 1430D...
2015 FREIGHTLINER CASCADIA DAYCAB (A58214)
2015 FREIGHTLINER...
