7 BH on 755 tractor
   / 7 BH on 755 tractor #1
Snowman9000
Grundy County, IL
JD 755
I have a chance to buy a nice used model 7 backhoe for my 755. Once the initial installation is done, how hard is it to install and remove the backhoe from the tractor? I have an old JD catalog that says something like "just remove two pins" to remove it. Sure sounds easy. But, is it?
   / 7 BH on 755 tractor #2
Easy.........somewhat.......quick.......maybe. I am not an expert.....but when I used to take my 7 BH offf of my old JD 770.....it took about 15 minutes. You need a level area, some good blocking and patience. The trick is to get it to sit right on the blocking and use the dipper stick to push and release your frame. It was something that I did not want to do every day. Good Luck:thumbsup:
black Max power washer (A53421)
black Max power...
2014 Dodge 5500 4X4 Bucket Truck (A55218)
2014 Dodge 5500...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
ASCO Transfer Switch (A52377)
ASCO Transfer...
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
