7 acres tilled - Whew!
   / 7 acres tilled - Whew! #1
pitt_md
Veteran Member
Pine Island, MN
Kubota MX5000
Well happy to say that we finally had a few nice days and I got my field preped and ready to plant. The guys on here that said that tilling more than 4 -5 acres would be a long haul were not kidding! My Befco T50-266 really did a great job. I think it took around 5 + hours of tilling to do the seven acres. The MX5000 went through about 10 galons of fuel to do it. The only problem I had was the 3pt pins worked loose a couple of times and I had a couple of loose tines after about an hour of use. I went through all of the tines and torqued them down and had no more problems with them. The 3pt pins need to have some lock tight applied. i am amazed at how well the tiller deals with rocks. If they are real big and just under the surface it will bounce up over them. Anything less than a bowling ball just gets mixed into the dirt.
Having the FEL on while doing this is the only way to go. I had picked the big rocks before I started but still ended up filling the bucket to the brim with rocks 3 times.
   / 7 acres tilled - Whew! #2
I till about 2 acres a year but I also use the tiller to cultivate between the rows when I'm growing veggies. 7 acres in one shot is impressive.
   / 7 acres tilled - Whew! #3
I tilled 8.5 acres numerous times last year prior to planting native grasses (planted the native grass 1 month ago). As much as I enjoy seat time, it really did get tedious. Glad I'm done with it. The tilling was very effective at eliminating the fescue. I didn't want to use Roundup so tilling was my best option (after plowing first, then discing)
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
MISC PIPE WRENCHES (A53843)
MISC PIPE WRENCHES...
Ranger Welder (A52377)
