7.3 powerstroke oil change
   / 7.3 powerstroke oil change #1
jaquetarr
Kerrville TX
PoiwerTrac 2445
When changing the oil in the Ford 7.3, does anyone drain / change the oil in the Reservoir on top of the engine? I think it operates the lifters or injectors. I would expect it drains back when the engine is stopped or has some type of overflow so the oil gets refreshed. This is a new engine to me and I'm looking for an experienced point of view.
Rgds,
tim
   / 7.3 powerstroke oil change #2
Yes, I've hear of people doing that. I don't think it's at all necessary however.
   / 7.3 powerstroke oil change #3
that is the HPOP (high pressure oil pump) reservoir. It is fed by the engine oil pump (pump that supplies oil to the bearings and lifters) and provides the oil to the HPOP which activates the fuel injectors. After actvating the injectors, the oil drains to the oil pan.
No need to drain it. You will use 15 qts of oil for an oil change so the small amount left in the reservoir wont hurt anything.
The key is quality oil. The HPOP system is very hard on oil (shearing). I change oil at 4k with Shell Rotella 15w40. Valvoline Extreme Blue is also very highly regarded.
If the HPOP is that hard on the oil, would an additive like Lucus help?
   / 7.3 powerstroke oil change #5
Oil additives are NOT recommended with the HEUI injector systems on the Powerstroke. The oil molecules themselves are sheared after a few thousand miles, and no additive can make the oil molecules re-combine themselves properly.
Run quality oil and change it every 4 or 5 thousand. I use dino Rotella T but of course some folks have other opinions. Since there are reports of folks getting over 1,000,000 miles out of a 7.3 even on dino oil, why mess with other stuff?
Oh, and I don't worry about the tiny bit of oil in the HPOP reservoir at oil changes. I don't think it's even a full quart, didn't seem like it when I drained it to upgrade my HPOP.
   / 7.3 powerstroke oil change #6
When I had my 7.3 I used Delvac or Delo and never had 1 single issue. For that matter I use Delvac in both my 6.0's. I never drained the resevoir you talk about. The cup left in there is nothing once you put 15 qts of fresh stuff in. I did 5K changes on all my diesels.
Chris
Thanks for all the input.
Rgds,
tim
   / 7.3 powerstroke oil change #8
Agree with above post love the Rotella T, but would add one add'l. bit of advise.......
Use the Ford/Motorcraft Oil Filter........Big difference than all others....Many articles on web, just pick up one from your local parts dept. at your Ford Dealer.
What year P/U do you have?? Mine is 2003 Ford F350 Lariat SCrew 7.3L Dually, man o' man do I love this truck.
Regards,
Big R
P.S. 1995 to 2003 Ford just recently had a Cruise Conrol recall on all, get free replacement at your local Ford Dealer.
"What year P/U do you have?? Mine is 2003 Ford F350 Lariat SCrew 7.3L Dually, man o' man do I love this truck."
I have a 2000 7.3 4x4 crew cab short bed F-250. It has about 195000 miles on it. And like you, I love this truck. I bought it used, it came with a chip with a 12 position knob. I don't know who made the chip and it seems to preform the same no matter what position I select.
I'll have to check on that Cruise Control recall, I haven't gotten any notification on it yet.
Rgds,
tim
   / 7.3 powerstroke oil change #10
Tim the Ford F250 is one the best looking trucks on the road, many people want that truck. Hang onto it as long as you can.
I'm thankful that I got the 7.3L and I'm just barely breakin it in with 64K miles..........nice knowing theres so many more miles ahead of us both, God willling.
Regards,
Big R
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A54607)
2017 INTERNATIONAL...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A51406)
2012 INTERNATIONAL...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2019 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2019 Top Hat...
UNUSED LANDHONOR LHR-G209 ANCHOR SHACKLES (A54757)
UNUSED LANDHONOR...
Leeboy 8500 Paver (A47477)
Leeboy 8500 Paver...
