7’ tiller advice
   / 7’ tiller advice #1
bdog
Elite Member
Texas
John Deere 6130M
Who makes the best 7” tiller? I am going to give one a shot and I foresee it getting a lot of use. Definitely not looking for the cheapest and I don’t need a Cadillac either but I want a brute of a tiller that can stand up to a lot of acres.
   / 7’ tiller advice #2
Local auction has one or two monthly lately.
I picked up a ~6' wide one for my tractor a couple years ago and it's seriously built - probably chinese (no stickers on it) - paid $1000 including tax and auction fee for an "unused" (definitely no wear but it had been outside at least a couple years). I'd advise checking for auctions around you for similar.
   / 7’ tiller advice #3
Best? Kuhn or Howard, if you have a decent Howard dealer... That is, IF you want something that can take a beating and last a LONG time!
It takes a lot of power to run a 7' tiller "properly", hope you have a tractor that's up to it.
SR
   / 7’ tiller advice
Thanks. What is a lot? 63 PTO enough?
   / 7’ tiller advice #5
7' tiller able to be used in all conditions will take more than 63 pto hp... Under ideal conditions with slower rotor speeds, it's just enough...
I like to speed the rotor up and use a bit higher ground speed, that means in most cases, you will be short on hp with a 7 footer.
SR
   / 7’ tiller advice #7
Why a tiller and not disk? Just curious.
Less compaction with a tiller, less trips across the field, better mixing of the soil, soil warms up earlier in the planting season ect..
SR
   / 7’ tiller advice #8
Maschio tillers are pretty stout..I would also look at woods.
   / 7’ tiller advice #10
The Maschio's with the bigger gear boxes are decent, I'd pass on Woods for this application...
SR
If you look at the OP,s original post he states I don't want a Cadillac but NOT the cheapest so I think woods fits this application.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
Toro Workman Utility Cart (A51694)
Toro Workman...
2019 Kenworth T270 Truck, VIN # 2NKHHM6X3KM358768 (A51572)
2019 Kenworth T270...
2012 RAM 5500 (A52472)
