6X4 Gator Idle Problem
   / 6X4 Gator Idle Problem #11
The gator hood is easy to remove (4 bolts and 10mm wrench or socket). Lift it off and check the wires that are under there. Might be lucky and find one that is obvious problem with an easy fix. Might have one chewed off by mice too.
So it ended ujp just being a loose wire in the starter relay... easy fix! Ang the electric lift issue, really wasn't an issue. I reconnected the wires, and plugged the power wire into the switch under the dash that had worked its way out! Spent a few minutes and tubed all the tires, so we are good there! Now just have to clean her up, and add some new seats and plastic! It's going to look brand new... Also, may get a can of bed liner spray for the inside of the box! Thanks for everyone's help!
2011 Chevy Avalanche (A50324)
2011 Chevy...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
71055 (A49346)
71055 (A49346)
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
Case 580D (A47384)
Case 580D (A47384)
