6v to 12v conversion
/ 6v to 12v conversion #1
judge the dog
Grove City
mitsubishi beaver 3, 46 case sc and NH TC29
I have a 1946 case sc. Its all original. It has no spark. Turns over but no spark. I suspect the mag is shot. What do i need to convert it to 12v? I am looking for a list of parts. A rebuilt mag is 500. A conversion is cheaper. Thanks
I think i would honestly rather convert it
/ 6v to 12v conversion #4
Convert what? The mag is self contained. Makes no difference if the tractor's electrics are 6 volt or 12. If you want 12 volts for faster cranking, that's one thing. You still need to deal with the mag as a separate issue. Probably just needs attention to the points. Cleaning/filing and adjusting the originals is probably a better bet than replacement with what's available on today's market.
/ 6v to 12v conversion #5
I agree. Old mags are great. The mag is completely separate from either 6 volt or 12 volt. Mags are designed to work all by themselves because they rotate when you crank the engine; they have no connection to the electrics in any way, just to the spark plug and a grounding wire running from the points cover used for turning the tractor off.
That simplicity & independence from the electrics is why a lot of light airplanes use mags.
First thing like Harry says is to check the points. I bet you can fix it in ten minutes. The most common thing that stops a mag from working is that the cam follower that opens the points wears down and the points don't open anymore. Take the obvious end off the mag and have a look. This is either very easy or you are looking in the wrong place. Look inside. The points have a little plastic arm that rides on a cam & should open them to about .010" at the high point. Remember, a mag only sparks when it rotates. So set it to compensate for about .012" of the wear that has happened and crank the sc. You should see a spark at the points and at the plug.
If not, ask around the local antique people to see who does mags.
rScotty
Great. Thanks to all. As soon as my other chores are completed i will start workibg on it. I appreciate all the advice. Ray
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
(15) SKLP SK-LJB-12 Polyethylene Road Bed Protection Pads (A64127)
(15) SKLP...
100 GALLON ALUMINUM TRANSFER TANK (A64277)
100 GALLON...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
