6th scv for 4-in1 added to 4520
   / 6th scv for 4-in1 added to 4520 #1
Cidertom
Benton Co Oregon
JD 4520, 2305 Aktive snow-trac ST4
After several requests for details and pix, here is my modification to add an electric valve as a 6th scv to my 4520 to enable a hand control. Basic concept: Using the power beyond I placed a solenoid valve in line to drive the 4-in-1 with a hand control on the main scv joystick.
I used a larger than needed valve to limit the pressure loss through the valve. It is a DO5 series with two solenoids providing push/pull/hold. The hold position links the P and T ports. The control handle is from Deere and is a part for the 110 TLB (pricey). The handle drives two relays, which fires the control valve.
Installing the valve: Made mount with strut. It would be prettier with a custom made weldment, but... The Mount is held up with 1" aluminum pipe segments 5" long and a fitting bolted to the connector mounts. I measured and cut the power beyond hydraulic line from the scv block, then brazed a fitting on. Wouldn't do it again. If I were doing it again, I would use a 5/8" hose with #10 JIC ends (adapt as required) . Remove the short end by removing the snapring from the coupler mount. Remove the steel tube and FF to O ring adapter. Install a hose from that coupler to the T port on the valve. Reinstall the snapring. Using a sweep elbow and a 90 deg hook the power beyond line to the P port. Currently I am using the couplers for the 4-in-1 lines. The 90 fittings on the end of the hoses are welded and I didn't want to fish them out to have them re-coupled (will happen this summer).
I replaced the short cord from the TLB handle with a longer one. I wouldn't do that unless you are used to circuit board re-work with thick conformal coatings. Instead just do a neat job of splicing an extension or find the matching connectors. Make certain you place snubber diodes on both the relays and the solenoids (total of 4) . I placed the relays in the RH fender compartment. I pulled a #10 wire with a 30 amp fuse from the battery terminal on the starter to the fender for this project and future lighting circuits.
It is not as smooth as a manual or porportional valve. For me it works OK. I have considered a restrictor or needle valve in line. The "book" would have a relief valve between the A-B ports.
Not suggesting this modification, if you do it: It's all on you.
Have fun
CT
   / 6th scv for 4-in1 added to 4520 #2
I'm not trying to be rude or anything but who needs 6 sets of scvs...
I frequently have my rear blade on: it uses 3 circuits. Tilt, offset and angle.
The frontloader uses 3: boom, bucket, 4-in1
total 6
   / 6th scv for 4-in1 added to 4520 #4
Nice job CT:thumbsup:
   / 6th scv for 4-in1 added to 4520 #5
My 2030 has 4, 2 mid for the loader an 2 rear, one of which I plug the grapple into.
The 6415 has 5, 3 mid and 2 rear. I plan to add a third rear with parts (all JD) bought off ebay and from the dealer.
Never know what you may want to hook up or build ;)
Can't have too much HP or SCVs :D
   / 6th scv for 4-in1 added to 4520 #6
Maximum I have is 3 on my 6420... :p
   / 6th scv for 4-in1 added to 4520 #7
Ya'll consider yourselves lucky, I have two. I also have a FEL that uses them and so need to unplug the FEL to run anything out back. I am working on seperating the buckets off the rear controls and adding a extra stick for a grapple. 5 minimum six is best I think:thumbsup::thumbsup:
   / 6th scv for 4-in1 added to 4520 #9
I wondered the same thing, but the answers here (front, rear, not having to plug/unplug) have convinced me it's a good idea.
Luxurious *for me* but that's cause I don't use it enough to ju$tify the expen$e.
Enjoy seeing member's ingenuity.
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
1327 (A58374)
1327 (A58374)
2019 TAKEUCHI TL10V2 SKID STEER (A52709)
2019 TAKEUCHI...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
