6mm grease zerk adapter
   / 6mm grease zerk adapter #1
johndeerefarmer
Bronze Member
Texas
Deere 6105R, Deere 620, Deere 340G, Deere 329D
Hi, not sure where to post this so i put it here. I have a grease zerk on my backhoe that won't take grease. I need an adapter to convert the 6mm grease zerk threads to a n 1/8" NPT so I can use my Milwaukee grease gun to force some liquid lubricant into the pin that won't take grease.
I could drill it out and retap it as 1/8" but prefer not to.
Thank
   / 6mm grease zerk adapter #3
Yeah - I have a screw driver that's been ground down to a fine point. Poke and loosen the ball. Still - no joy. Remove the zerk - GENTLY heat with a propane torch. Still - no joy. Replace the dam thing.
None of you read the post. It's not the zerk that's bad. It's been replaced. The pin won't take grease and I can't get the pin out to clean it.
   / 6mm grease zerk adapter #6
One of these would probably work. I’d send one out to you but I don’t have any left.
Or heat up the bushing (with zerk removed) with a torch before trying with the grease gun again.
   / 6mm grease zerk adapter #8
OK - my bad. The pin won't take grease. I have one zerk on one of my pivot pins that is a tough customer. I have to rotate the grapple. Then the zerk will take grease on into the pivot pin.
   / 6mm grease zerk adapter #9
That is not uncommon. The pin probably only has one hole and when you have the grapple in certain positions the hole is under the pressure point preventing grease from flowing.
   / 6mm grease zerk adapter #10
Did you remove pin and try to clean grease channel through pin or rotate pin 90 or 180 degrees.... Problem may not be zerk....
Dale
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
