6ft Rotory Tiller not getting job done
   / 6ft Rotory Tiller not getting job done #11
Should say in your manual if you can and how to change the direction it was a little in depth process mechanically for mine anyway. Imo it will make a difference provided your slip clutch is properly adjusted.
   / 6ft Rotory Tiller not getting job done #12
Depends partly on the soil you are tilling.
Sometimes you just have to run a plow or cultivator tool bar through to break it so the tiller can do something with it.
Neighbor just got a new tiller and it barely scratched the dirt. It just couldn't get a bite.
One pass with a cultivator bar on one edge and the tiller got down and could work the rest.
   / 6ft Rotory Tiller not getting job done #13
I'd run a disc thru it several times then till it.
   / 6ft Rotory Tiller not getting job done #15
You said you got under the tiller to find the slip clutch adjustment, And that it was a pain to hook up. Neither of those sound right , Also it helps a great deal to spray with glyphosate weeks in advance of tilling killing those roots and letting them decay , I have tilled lots of virgin soil this way, Otherwise as others have said , cultivate first , around here old used cultivators are easy to find,
   / 6ft Rotory Tiller not getting job done #16
The tiller's Slip-Clutch PTO protection keep the tines from running most of the time, basically making very little progress. I went over the land three times, having to adjust 3pt manually up just scraping the dirt so didn't engage the Slip=Clutch PTO protection. Painfully slow process. End result is maybe 2-3 inches of depth of till.
The slip clutch is slipping most of the time and you went over the area 3 times and only managed to go 3" deep? Is the tractor a hydro or gear transmission? How fast are you going? Are you running the tiller at 540 PTO speed?
I would lower the 3pt to dig 6" and tighten the clutch so it doesn't slip when going very slow.
   / 6ft Rotory Tiller not getting job done #17
Something definitely seems off. I run a Frontier 5ft reverse tine tiller behind a 3032e and it goes through grass covered Oklahoma clay like it was butter. I'm told what we have is technically "silty clay" but it holds water and looks like plain old clay to me. The last half acre deer plot I put in on ground that had never been cultivated took maybe an hour so it doesn't go fast (no idea how long it's supposed to take) but I've never had the tines slow down or stop, and that's running it at max depth right off the bat. I'd guess your tractor and a 6ft tiller should be able to do that work a lot faster than mine.
   / 6ft Rotory Tiller not getting job done #18
Hard ground here in Colorado & I have a 5' King Kutter farm store special. It has a hard time if I don't rip first. I either use a subsoiler or scarfiers on my box blade or land plane. It tills good after ripping. I want a heavier 6' to match my new tractor. But the 5' KK has done well so far. Tines are about toast & half the size they are up near the rotor. I've put a lot of hours on it doing horse arenas.
Tighten the clutch as others have said. If you let it slip for minutes on end it's probably toast already though. You should have it adjusted so it rarely slips under normal operation.
Annually loosen up the clutch completely. I generally jam a 2x4 into the tines & turn on the PTO. Sometimes the rust & gunk alone is enough to hold the clutch together & slice the 2x4. Once the clutch is freed up tighten things a bit & jam the tines again. Slip the clutch for a few seconds to clean the rust off but not heat everything up much. Then tighten to spec. If you don't clean & check the clutch annually or so it's likely to be rusted solid & notvwork when you actually need it.
   / 6ft Rotory Tiller not getting job done #20
New 48hp tractor and 6ft Tar River tiller. Others told me this tiller is a good unit, and I trust their opinion. My land hasn't been farmed in 3 years, so weeds have grown. I mowed the weeds down first. I then hookup up my tiller and gave it a try. Ground is clay, loam so not exactly peat. The tiller's Slip-Clutch PTO protection keep the tines from running most of the time, basically making very little progress. I went over the land three times, having to adjust 3pt manually up just scraping the dirt so didn't engage the Slip=Clutch PTO protection. Painfully slow process. End result is maybe 2-3 inches of depth of till.
I'm wondering if I first need to get a small cultivator this run over this ground first? I have about 6 more acres to go and seems very inefficient to continue with the tiller like this. Can anyone think i'm missing anything here? I'd love to just keep the tiller on and not swap it out and buy another implement (plus hooking up the tiller was a pain in the @ss). Thank you
I followed your link for the tiller. It has a gearbox for an 18 to 30 hp tractor. Your tractor has 35.9 hp at the pto. That's probably close enough, but you are still over powering it a bit.
If your clutch plates still have some wear left on them, tighten the adjustment bolts half a turn and see if that helps.
The tiller is 412 pounds, so it should be doing a better job.
Year: 2000 Make: Chevrolet Model: C2500 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 D... (A55852)
Year: 2000 Make...
2010 Toyota Prius Hybrid Hatchback (A55758)
2010 Toyota Prius...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A55787)
2024 AGT LRT23...
1984 Gleaner A630 Corn Head (Deutz-Allis branded) (A55301)
1984 Gleaner A630...
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EFXFFA41510 (A54865)
2015 Ford F-150...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
