69' Ford 3000 S.O.S. stalling
   / 69' Ford 3000 S.O.S. stalling #1
bigdman66
Willington, ct
Ford 3000
I have a Ford 3000 gas. when its hot out the engin stalls and wont start till it cools down 10-20 min, also when its running agian when its hot out side there is a smell of raw fuel but no signs, any ideas
   / 69' Ford 3000 S.O.S. stalling #2
Would start with carb, looking for sticking/leaking float or float valve, check float level adjustment, mixture too rich.
   / 69' Ford 3000 S.O.S. stalling #3
i had a similar problem out of my 4500 and what seem to fix it was rebuild the carb. I got the kit off ebay for less than 40 bucks. When i took the carb apart what i call the plunger was gummed up. I could be using the wrong term of what the part is called but thats what it looked like
   / 69' Ford 3000 S.O.S. stalling #4
at moment of stall, check spark.. if spark is good.. start hunting fuel. don't overlook the pump in front.. strainers.. etc..
The carb was replaced new year ago, i did open it up, cleaned out checked float/valve all working, nothing sticking, on the fuel pump it works when i checked it cold, is it possible that when the pump gets hot it stops working?
   / 69' Ford 3000 S.O.S. stalling #6
doubtfull.
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
Vintage Signs (A50324)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
