69' Ford 3000 S.O.S. stalling
   / 69' Ford 3000 S.O.S. stalling #1
bigdman66
Willington, ct
Ford 3000
I have a Ford 3000 gas. when its hot out the engin stalls and wont start till it cools down 10-20 min, also when its running agian when its hot out side there is a smell of raw fuel but no signs, any ideas
   / 69' Ford 3000 S.O.S. stalling #2
Would start with carb, looking for sticking/leaking float or float valve, check float level adjustment, mixture too rich.
   / 69' Ford 3000 S.O.S. stalling #3
i had a similar problem out of my 4500 and what seem to fix it was rebuild the carb. I got the kit off ebay for less than 40 bucks. When i took the carb apart what i call the plunger was gummed up. I could be using the wrong term of what the part is called but thats what it looked like
   / 69' Ford 3000 S.O.S. stalling #4
at moment of stall, check spark.. if spark is good.. start hunting fuel. don't overlook the pump in front.. strainers.. etc..
The carb was replaced new year ago, i did open it up, cleaned out checked float/valve all working, nothing sticking, on the fuel pump it works when i checked it cold, is it possible that when the pump gets hot it stops working?
   / 69' Ford 3000 S.O.S. stalling #6
doubtfull.
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
Wolverine Log Splitter (A50515)
Wolverine Log...
Rhino 484 84in Rotary Cutter (A50322)
Rhino 484 84in...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
