68 ford 3000 tractor
/ 68 ford 3000 tractor #1
phoneman1121
crossville
68 ford 3000
hello everyone!!
I was needing to replace the pto shaft seal on my ford 3000,with a 4 speed transmission, and got in a big hurry and forgot to engage the pto shifter before i pulled the shaft out. Got the shaft out and engaged the pto shifter and heard something fall inside the tractor!! Took the pto shifter off and the inspection cover and cant find anything at all laying in the bottom of the tractor.
I was assuming looking for a shifting collar or something in that nature but no luck !! What am i missing/ Please help!!:):)
Have u got a pic and where do I need to be looking ?
/ 68 ford 3000 tractor #4
It's going to be laying in the bottom of the case. Probably towards the front. I don't have a picture. If the PTO worked before you pulled the shaft, and the coupler isn't on the ground Under the tractor, it's inside the rear end housing.
what shape does it look like? the reason why i ask is because i have had my hands all in the bottom of the case where the pto shifter is located and i cant find anything laying loose and have stuck a stick magnet in as well and cant drag anything out as well.
2006 Ford F-350 4x4 Ext. Cab Reading Service Truck (A66736)
2006 Ford F-350...
2014 MAGNUM FRAC MANIFOLD TRAILER (A67714)
2014 MAGNUM FRAC...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2017 HINO 338 REFRIGERATED 26FT CDL REQUIRED BOX TRUCK (A69167)
2017 HINO 338...
2006 FORD E250 CARGO VAN (A66091)
2006 FORD E250...
2025 CATERPILLAR 265 SKID STEER (A65056)
2025 CATERPILLAR...
