Mowing 66" mid mower on a ct230 or 235
   / 66" mid mower on a ct230 or 235 #1
650JD
mid west
Kubota ZD331
I just tried out a ct225 with the 66" mid mower and wasn't very impressed with the power. I noticed a bog at full speed in medium range (6.4 mph according to the brochure) Has anyone experienced this with the 230 or 235? The rest of the tractor seems great and I want to buy one but im worried about hp.
Thanks,
Joe
   / 66" mid mower on a ct230 or 235 #2
I have tried out several compacts.... still do not know as to what one I want ... they all have good points and bad! But if I want to cut my grass I will just use my Simplicity with the 60 inch cut.... I want a compact to do "WORK" with a loader, tiller, scraper, Blade, etc...
I tried the New Bobcats and it seems like they just dont have the "POWER" and I dont like where all the controls are located at... I started spinning in just a little bit of mud and had a hard time pulling myself out with the loader bucket!!! seems kinda weak... but then again I am used to my 580k 4X4 extendahoe.... much more power and weight and could do a heck of alot more work!!
So if you want a cutter for grass get a pull behind or a lawnmower....... these compacts are made to work!!! hauling, digging, and braking the soil!!!
So I guess thats My 2 cents worth... :D so on that note I will bid thee a fine day!
has anyone had any experience mowing with a CT230 or 235? I Know that a zero turn is the best machine for the job but I need the versatilty of a compact and there is only room for one in the garage and the budget :D
   / 66" mid mower on a ct230 or 235 #4
hey 650....
You may want to try running in 4 wheel drive. Especially if you've been getting a lot of this rain lately and the soil is soft. In 2 wheel drive you end up "pushing" the front tires pulling the engine down...4 wheel drive will pull you through actually lightening the load on the engine.
Give it a try let me know....
The lawn at the dealership had just been mowed a couple days before and it was flat and dry. Next time I get on one I'll try 4wd and see if it does any better. Thanks for the input :)
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2020 Caterpillar...
Electric Mobility Scooter (A51694)
Electric Mobility...
2018 Autocar ACX Xpeditor Garbage Truck (A55852)
2018 Autocar ACX...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
